MOBO MSI MS-7848 ram problem.
1 ANTWORT 1
h4ashy
Nachricht 1 von 2
2.237 Aufrufe
Nachricht 1 von 2
2.237 Aufrufe
Hi. Is there any way to set ram frequency to 1600MHz from 1333MHz in MS-7848 bios? I don't see any option that allows me to change my ram frequency. My ram is 2x8 1600MHz. Motherboard set it to 1333MHz.
1 ANTWORT 1
Gehringer
Retired
Nachricht 2 von 2
2.229 Aufrufe
Nachricht 2 von 2
2.229 Aufrufe
Hi @h4ashy ,
depending on the version of your BIOS and your motherboard, this option should be found at the "advanced chipset" section, under RAM/DRAM config menu.
Be aware that this BIOS change may pose a threat to your system and Medion can't take any responsibility for the consequences of this act.
Regards,
Gehringer
1 ANTWORT 1
