MEDION ERAZER RECON P20 new RAM
38 REPLIES 38
Juze-81
Message 1 of 39
Message 1 of 39
CPU Int I5-12400F
RTX 3060 12GB
Bios B660H7WOX.107
Originally, the computer had 1x8G 2400Mhz cl22 RAM memory. I bought new RAM memory cards 2x8G 3200Mhz, cl16 dual rank. The computer shows 16g RAM memory, but only 2133mhz. I can't find in the bios where I can adjust the RAM memory in any way. Are these the wrong RAM memory cards or am I doing something wrong?
I bought these
https://www.gskill.com/product/165/184/1536110676/F4-3200C16D-16GVKB
38 REPLIES 38
plutissimo
Message 11 of 39
Message 11 of 39
@Juze-81
Did you try out updating the Bios with the one linked by @Major_ToM ?  Did it include any improvements or new capabilities vs the stock bios B660H7W0X.107?
/plutissimo
Juze-81
Message 12 of 39
Message 12 of 39
No, because he never told what this bios update contains. Also the given link doesn't make it clear what the update contains either. It doesn't even read what the bios update contains on the manufacturer's website, so I won't take the risk. Update might brick the whole mobo or i just gain some stupid things what no1 needs. I really hope they improve their information regarding updates. unbelievable.
Mastermind
Message 13 of 39
Message 13 of 39
hi @Juze-81 and thank you @plutissimo and @Fishtown for your helping comments.
The download file of the recent version of the Bios contains a file named ReleaseNote.txt . Did you take noithice of it?
Cheers
plutissimo
Message 14 of 39
Message 14 of 39
Thanks @Major_ToM .
I'll try the bios update that you just posted and see what improvements there are.
However, the "readme" file did not contain any instructions for the bios update. And there are several program files in the zip-folder.
Which one should I run? Are there any instructions somewhere else?
/plutissimo
Mastermind
Message 15 of 39
Message 15 of 39
Hi @plutissimo ,
that´s why I mentioned to throw an eye on the file ReleaseNote.txt.
There are several options to run the update and one is to start the WFH.bat via right click and chosing "Run as administrator" from the context menue,after having unzipped the downloaded file.
Cheers
plutissimo
Message 16 of 39
Message 16 of 39
@Major_ToM
Tried running the WHF.bat file (as adiminstrator as instructed) but nothing happens. After approving that windos run waht it deems as un unsafe software, then... nothing. I tried multiple times.
Any other way to start this FW update?
/plutissimo
Mastermind
Message 17 of 39
Message 17 of 39
Hi @plutissimo ,
we´ll contact the manufaturer trying to arrange a more "cx friendly" Bios version, which can be run as "Winflash", so please show a little patience.
Cheers
plutissimo
Message 18 of 39
Message 18 of 39
Hi @Major_ToM ,
OK. Then I will wait for you to post an update when its available.
Thanks,
plutissimo
Mastermind
Message 19 of 39
Message 19 of 39
Hi @plutissimo & @Juze-81 ,
I now can provide the Bios version 1.12, which can be updated via the device manager after unzipping, which should look similar to this scenario shot from the B550A4 mainboard.
Cheers,
plutissimo
Message 20 of 39
Message 20 of 39
Hi @Major_ToM ,
Thanks for the file and the instruction. However, it doesn't seem to be working on my B660. It gets stuck in the updating firmware process and never gets past that point (see screenshot below). I let it run for over 1 hour, before trying to cancel. But now it doesn't let me do that either. Great...:-(
Any other instructions? At some point I have to shut down the computer and then we'll see what happens... If it boots up again after all...
38 REPLIES 38
