HELP - MEDION ERAZER P66078 Unexpected power off
11 RÉPONSES 11
rayalco
Message 1 sur 12
3 217 Visites
Message 1 sur 12
3 217 Visites
Hi I have a Desktop
MEDION ERAZER P66078 (MD 34629) UK, MSN: 1002 3317, PC System D098 UK
This unit has a GTX1650 in it and I am running windows 11.
It is out of warranty by 8 months
It has started to shut down unexpectedly and it is doing more frequently.  The computer will be running and then all power goes off.   It will not restart after this.  To get it to restart you have to physically unplug the power cable and wait a few seconds, plug it back in and it powers up.
I first noticed on steam games so I thought it was GPU overheat.  I have been monitoring system and GPU temps and making sure there is sufficient fan cooling applied.  The system has become more unstable and just shuts down when using teams or other simple desktop apps.   I am not seeing GPU overheat triggering this.
I have replaced the PSU with a new higher power PSU as all signs were pointing to a faulty PSU.  Clearly that is not the problem.
What else can cause a PC to stop completely and suddenly as if the power was switched off.   What else can I try to isolate the issue?  I dont have another GPU or another desktop machine to go swapping bits.
Hoping for some pointers.  Thanks
11 RÉPONSES 11
rayalco
Message 11 sur 12
533 Visites
Message 11 sur 12
533 Visites
Just an update.. I got the shut down on the original hard drive so problem is not solved.
I also had the 500GB WD drive replaced under warranty. I put that in and was installing windows and go the shur down again... so its not the harddrive
Message 12 sur 12
493 Visites
Message 12 sur 12
493 Visites
Hi @rayalco ,
maybe it does sound wayyy to simple, but did you ever perform a test with the MEDION diagnostics tool?
https://www.medion.com/gb/service/service-app
Feedback really appreciated.
Cheers
11 RÉPONSES 11
