Erazer medion start up issues
4 REPLIES 4
AlfieA
Message 1 of 5
Message 1 of 5
Evening
I am a computer novice and I'm having difficulty starting up my PC?
I can't seem to connect the PC to the monitor.. I have tried a HDMI and a VGA but I can't seem to get anything on the monitor? All I get on the monitor is power saving mode.
I know the monitor works as I have used it previously?
Any help would be greatly appreciated as buying a pre built PC I thought this would be easier.
Thank you
4 REPLIES 4
Message 2 of 5
Message 2 of 5
Hello @AlfieA and welcome,
in order to be able to tell you more, more information is required from you.
please state the MSN number of the device.
bye Fishtown
AlfieA
Message 3 of 5
Message 3 of 5
Hello @Fishtown, thank you very much for your response. I believe my MSN number is 10024314. Hope this is of some help. Thanks again.
Message 4 of 5
Message 4 of 5
Hi @AlfieA
you have a ERAZER Engineer P10 (MD 34625) A-UK  !
It has happened several times before that users have used the connections from the board. they are closed with a cap and are not active. You may only take the connections from the graphics card.
bye Fishtown
AlfieA
Message 5 of 5
Message 5 of 5
@Fishtown , Brilliant! You're a life saver, thank you so much.
4 REPLIES 4
