Documentation searched MEDION P10
7 ANTWORTEN 7
claudio53de
Nachricht 1 von 8
6.180 Aufrufe
Nachricht 1 von 8
6.180 Aufrufe
On amazon (medion store) is available this model
MEDION P10 SILVER E32005 Desktop PC (Amd Ryzen R5-3400G, 256 GB SDD, 8 GB di RAM, AMD Radeon, Windows 10)
Unluckily nowhere on the community or on medion website I can find detailed tech infos (Motherboard and so on)!
7 ANTWORTEN 7
Gehringer
Retired
Nachricht 2 von 8
6.177 Aufrufe
Nachricht 2 von 8
6.177 Aufrufe
Hi @claudio53de , welcome to the FORUM!
Can you please check if this one is the model you've been looking for?
If it is, you will find a clickable "technical specifications" menu when you scroll down the page a little bit.
Regards,
Gehringer
claudio53de
Nachricht 3 von 8
6.168 Aufrufe
Nachricht 3 von 8
6.168 Aufrufe
https://www.medion.com/gb/service/product-detail/10022472?fromTopicsPage=true
Wrong link
it leads me to a wrong page
THNX anyway
Gehringer
Retired
Nachricht 4 von 8
6.157 Aufrufe
Nachricht 4 von 8
6.157 Aufrufe
Hi @claudio53de ,
I am sorry for that.
Please go to our service page here and search using the MSN 10022472.
Regards,
Gehringer
claudio53de
Nachricht 5 von 8
6.148 Aufrufe
Nachricht 5 von 8
6.148 Aufrufe
something similar but not exactly... in real what I need is tech spec for MB ( ECS B350A4-EM) and precisely how many sata connectors free left (two are used by optical and HD, so probably 2 more)
Nachricht 6 von 8
6.146 Aufrufe
Nachricht 6 von 8
6.146 Aufrufe
Hi @claudio53de
correct,
4x SATA III ports (4x black color = SATA III)
bye Fishtown
Nachricht 7 von 8
6.070 Aufrufe
Nachricht 7 von 8
6.070 Aufrufe
Hi @Gehringer
It is not easy to find out about this PC. (Not stored in the intranet for superuser 😭)
there is an E32005 that would also fit. E32005 / MSN 10023400 / MD 34658 / R5-3400G
https://media.medion.com/prod/medion/nl_NL/0855/0776/0772/10023400-A1.pdf
but when I enter this under "find my product" does it come to the fore only when
I click on it it becomes an E300001 / MSN 10023409 / MD 34657 / R3-3200G
testet: https://www.medion.com/de/service/topic/medion-products?msnCheck=10023400
Both MSNs have a B550A4-EM 2X00 board / Look here:
https://community.medion.com/t5/FAQs/FAQ-Technische-Spezifikationen-f%C3%BCr-das-Mainboard-quot-ECS-...
The specification with the 4SATA connections is still correct, because both boards have this.( B550 + B350)
Bye Fishtown
Note: @claudio53de  has opened a German post with a link to the PC you are looking for:
https://community.medion.com/t5/Desktop-PC-All-In-One/technische-Infos-MEDION-P10-gesucht/m-p/113110...
Pictured SN on the picture: 1C38101020007 maybe you can find something about it in the database
claudio53de
Nachricht 8 von 8
6.006 Aufrufe
Nachricht 8 von 8
6.006 Aufrufe
Thanks to both HELPERS
it did help a little because it can be similar to the searched specs
Trotztem is not exactly the same model.
It's a very attractive model (for my needs) but I'm afraid that in case I can't find the right support (driver, download etc) should I buy it.
Vielen Dank, many thanks BEIDE!😃
7 ANTWORTEN 7
