Can I install a new CPU with integrated graphics card on my Medion Akoya E23401
2 REPLIES 2
marmarreid
Message 1 of 3
Message 1 of 3
Can I install a new CPU with integrated graphics card on my Medion Akoya all-in-one E23401?
Lately my graphics display is badly distorted. I have tried all sorts of things like updating driver, reset Windows, clean reinstall of Windows 11. I am now using a an external display monitor but wany my original all-in-one display back working properly.
I looked to see if I could just install a new graphics card Intel UHD 620. However a few googles tells me it is integrated in the CPU Intel Core i5-8250U.
So can I replace CPU that will also replace the GPU?
How easy is it to do this? Do I need to consider anything else when doing this?
Device name Sunnyhill
Processor Intel(R) Core(TM) i5-8250U CPU @ 1.60GHz 1.80 GHz
Installed RAM 16.0 GB
Device ID D3EB2C75-4071-4F1D-B2A2-2C3A121869AA
Product ID 00325-96633-28196-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
Edition Windows 11 Home
Version 22H2
Installed on ‎27/‎10/‎2023
OS build 22621.2361
Experience Windows Feature Experience Pack 1000.22674.1000.0
Thanks for any help
Mark
1 ACCEPTED SOLUTION
Message 2 of 3
Message 2 of 3
Hello @marmarreid and welcome
Yes, it is true that the CPU I5-8250 has integrated Intel UHD Graphics-620. The CPU has a BGA1356 socket. BGA = soldered.
So it cannot be changed for a normal user.
bye Fishtown
2 REPLIES 2
Message 2 of 3
Message 2 of 3
bye Fishtown
marmarreid
Message 3 of 3
Message 3 of 3
Thanks Fishtown. What would you suggest? Should I bring to my local computer repair shop?
Everything is working fine apart from the graphic display has lots of black lines and very fuzzy.
Is it possible to repair?
Kind regards
Mark
2 REPLIES 2
