BIOS Update for H81H3-EM2, Medion Akoya P2228 D/C037
4 REPLIES 4
Phum
Message 1 of 5
Message 1 of 5
Hello community,
I bought a new CPU (i5-4690K) to replace it with the old standard i3-4160. I was told that I needed to update my bios but I can't seem to find the right link to the biosupdate. The only link I can find is: https://www.medion.com/nl/service/_lightbox/treiber_details.php?did=13978 . But it says that the system is: Win8.1 64bit. But I have Win10 64bit
My MSN: 10021381
Windows Version 10
Desktop: MEDION AKOYA P2228 D/C037
Please help me
1 ACCEPTED SOLUTION
Phum
Message 5 of 5
Message 5 of 5
Hello @Gehringer,
I stopped researching and finding answers, I bought a hole new motherboard. The last thing I tried was downgrading my pc to Windows 8.1, since the bios update was for windows 8.1. But without success, so I just stopped everything with this mother board. And bought the ASRock Z87m Pro4. But answer to your question
-Version 2.8
-I can’t see it anymore cause I took my pc apart
-I instructed myself to update the bios because the cpu didn’t work and I saw a few posts from people with the same motherboard but with a updated bios version and their cpu (same cpu as mine) functioned correctly
-I already did but without success
Yes I know but I am keeping the processor and replacing the motherboard
Regards,
Phum
4 REPLIES 4
Gehringer
Retired
Message 2 of 5
Message 2 of 5
Hi @Phum ,
what is the Windows version that was originally installed in your PC?
Regards,
Gehringer
Phum
Message 3 of 5
Message 3 of 5
Hello @Gehringer,
Thankyou for the fast reply,
It was originally installed in windows 10
Gehringer
Retired
Message 4 of 5
Message 4 of 5
Hi @Phum ,
since we are talking about a BIOS update, we need to be careful.
Can you please provide me further information?
- What is your current bios version
- What is your current motherboard version (use data from CPU-Z utility)
- Who has instructed you to update BIOS and why?
- Would you be willing to try swapping the processor without a Bios update?
If you buy the processor from websites that accept returns you would be even safer if something goes wrong
Regards,
Gehringer
Phum
Message 5 of 5
Message 5 of 5
Hello @Gehringer,
-Version 2.8
Regards,
Phum
4 REPLIES 4
