DECT set, 2nd handset
2 REPLIES 2
Idiocrazy
Message 1 of 3
Message 1 of 3
On my DECT set Life S63012 I cant seem to get the second handset to work anymore. I remember it worked when I first got the set years ago, now I need it again, but the display only says "register". When I try to register it, it doesnt seem to find the main unit, the main handset works without any issues.
Any bright ideas?
2 REPLIES 2
Bodgekin
Message 2 of 3
Message 2 of 3
Hi @Idiocrazy
When you try to register it, did you first push the "page" button on the main unit?  See page 47 in this manual
I remember running into similar problems with my DECT set (not Medion though) because I forgot to push a button on the base unit.
Kind regards,
Bart
doria786
Message 3 of 3
Message 3 of 3
Sometimes resetting the handset can resolve registration issues. Remove the batteries for a minute, then reinsert them and try again. On the main unit, there should be a “page” button. Press this button before attempting to register the handset. Check for any possible sources of interference near the main unit or handset that could be preventing registration.
2 REPLIES 2
