Medion Gaming Centre Hogging RAM randomly
14 RÉPONSES 14
Sibz
Message 1 sur 15
15 222 Visites
Message 1 sur 15
15 222 Visites
Hi everyone,
I have an Erazer x6807 and have realised that Gaming Centre hogs up to 50% of the RAM for no reason at all.
Is there a reason for this? How can I prevent it?
Thank you,
Sibz
1 SOLUTION APPROUVÉE
Solutions acceptées
Gehringer
Retired
Message 4 sur 15
10 313 Visites
Message 4 sur 15
10 313 Visites
Hi @Sibz ,
please try reinstalling the control center.
You can download it from this link here
Regards,
Gehringer
14 RÉPONSES 14
Gehringer
Retired
Message 2 sur 15
10 326 Visites
Message 2 sur 15
10 326 Visites
Hi @Sibz ,
can you please provide the MSN number of your unit?
Regards,
Gehringer
Sibz
Message 3 sur 15
10 321 Visites
Message 3 sur 15
10 321 Visites
Hi @Gehringer ,
My MSN number is 30026173.
Thanks,
Sibz
Gehringer
Retired
Message 4 sur 15
10 314 Visites
Message 4 sur 15
10 314 Visites
Hi @Sibz ,
Regards,
Gehringer
Sibz
Message 5 sur 15
10 300 Visites
Message 5 sur 15
10 300 Visites
@Gehringer ,
I am sorry for the late response. I have done this before and after some time the issue reappears.
I will accept this as a solution and wait to see if the issue comes up again.
Thank you.
Sibz
Message 6 sur 15
10 248 Visites
Message 6 sur 15
10 248 Visites
Hi @Gehringer ,
As I suspected the issue has come up again.
Please see the screenshot below.
RAM hogging Gaming CentreRAM hogging Gaming Centre
Gehringer
Retired
Message 7 sur 15
10 224 Visites
Message 7 sur 15
10 224 Visites
Hi @Sibz ,
this print shows that the gaming center is using only 24 MB of memory, which is not much.
Please order the list of apps running as per memory usage and check whether or not you have unnecessary apps running, even on background.
Also, please go to the startup apps menu on your W10 (start menu -> settings -> apps & features -> Startup) and review the list of apps that are defined to run when your unit starts.
That should do the trick.
Regards,
Gehringer
Sibz
Message 8 sur 15
10 213 Visites
Message 8 sur 15
10 213 Visites
Hi @Gehringer,
The apps were listed in order of ram usage and gaming center was using 24 GB of it. The values are in MB not KB.
Kind regards,
Arthur
Gehringer
Retired
Message 9 sur 15
10 191 Visites
Message 9 sur 15
10 191 Visites
Hi @Sibz ,
have you added RAM memory to your unit?
Regards,
Gehringer
Sibz
Message 10 sur 15
10 154 Visites
Message 10 sur 15
10 154 Visites
Hi @Gehringer,
Yes, I have 32GB of RAM.
It still happened when I had the stock 8GB RAM.
Kind regards,
14 RÉPONSES 14
