Medion Control Centre
25 ANTWORTEN 25
Ikari_00
Nachricht 1 von 26
39.656 Aufrufe
Nachricht 1 von 26
39.656 Aufrufe
Hello, I recently purchased a refurbished Medion Erazer X7853 which has had its hard drives reformatted. As a result, I do not have the Medion Control Center installed onto my laptop which means that I cannot access the RGB keyboard. I have looked for a download link online but have not had any results. Would anyone be able to provide a download link to it? Thanks.
25 ANTWORTEN 25
TPFLegionaire
Retired
Nachricht 11 von 26
34.803 Aufrufe
Nachricht 11 von 26
34.803 Aufrufe
hi @Ikari_00
Realy pleased to hear it has worked for you. this is great! Let us know if there is anything else we can do to help.
@Fishtown access is one thing, finding what you are lookingfor , now that is the challenge! Teamwork, community that is the key ,for if I fail, someone else will help and in this instance it was you @Fishtown ! Many thx.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Nachricht 12 von 26
35.146 Aufrufe
Nachricht 12 von 26
35.146 Aufrufe
Moin @Ikari_00 ,
if the contribution is solved for you, mark it as such, thank you.
here again the direct link to the controll center: http://cdn.medion.com/downloads/treiber/ctrx785x_w10.exe
Teamworker@TPFLegionaire , thanks for the enlightening answer
Tschüss Teamplayer Fishtown
if you are looking for something let me know.Smiley (zwinkernd)Lachender Smiley
martymcfly
Nachricht 13 von 26
12.715 Aufrufe
Nachricht 13 von 26
12.715 Aufrufe
Great post. I needed that app as my drive died.
Thanks.
kyzarvs
Nachricht 14 von 26
12.676 Aufrufe
Nachricht 14 von 26
12.676 Aufrufe
Hi,
I've just reformatted a new Beast x10 laptop. The version of control center in the link here doesn't allow me to change the four RGB sections - I'd like them all one colour and they are currently R / G / B / lilac.
I realise the FN+ combos let me turn them off, but I'd like to be able to change them.
Thanks,
Joe
martymcfly
Nachricht 15 von 26
12.671 Aufrufe
Nachricht 15 von 26
12.671 Aufrufe
Funny enough I also cannot change the RGB on the Keyboard. I just thought it was the new Keyboard.
Glad it's not just me but I can't see anyway to fix this issue.
kyzarvs
Nachricht 16 von 26
12.664 Aufrufe
Nachricht 16 von 26
12.664 Aufrufe
Before I reformatted I had a vesion of the software that worked fine - I just presumed that I would be able to download it from the support website. Bit of a shame as I have to upgrade to W10 Pro for work, so couldn't keep the default W10 Home install.
Twm
Nachricht 17 von 26
11.470 Aufrufe
Nachricht 17 von 26
11.470 Aufrufe
would it be possible to do the same for my x7351?
I did have the control centre but it got wiped at the pc shop..
blue backlight really isn't doing it for me!
thanks!
Nachricht 18 von 26
11.465 Aufrufe
Nachricht 18 von 26
11.465 Aufrufe
Hello @Twm  and welcome,
are you sure you have an X7351 with a controller center?
bye Fishtown
Twm
Nachricht 19 von 26
11.462 Aufrufe
Nachricht 19 von 26
11.462 Aufrufe
Thank you! I'm not sure what it was called, however I could previously change the colours.
wishing I never took it into the shop really.
cheers!
Nachricht 20 von 26
11.460 Aufrufe
Nachricht 20 von 26
11.460 Aufrufe
Hi @Twm if the specification x7351 is correct please state your MSN number
bye Fishtown
25 ANTWORTEN 25
