Medion Control Centre
25 ANTWOORDEN 25
Ikari_00
Bericht 1 van 26
39.830 Weergaven
Bericht 1 van 26
39.830 Weergaven
Hello, I recently purchased a refurbished Medion Erazer X7853 which has had its hard drives reformatted. As a result, I do not have the Medion Control Center installed onto my laptop which means that I cannot access the RGB keyboard. I have looked for a download link online but have not had any results. Would anyone be able to provide a download link to it? Thanks.
25 ANTWOORDEN 25
TPFLegionaire
Retired
Bericht 11 van 26
34.945 Weergaven
Bericht 11 van 26
34.945 Weergaven
hi @Ikari_00
Realy pleased to hear it has worked for you. this is great! Let us know if there is anything else we can do to help.
@Fishtown access is one thing, finding what you are lookingfor , now that is the challenge! Teamwork, community that is the key ,for if I fail, someone else will help and in this instance it was you @Fishtown ! Many thx.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Bericht 12 van 26
35.288 Weergaven
Bericht 12 van 26
35.288 Weergaven
Moin @Ikari_00 ,
if the contribution is solved for you, mark it as such, thank you.
here again the direct link to the controll center: http://cdn.medion.com/downloads/treiber/ctrx785x_w10.exe
Teamworker@TPFLegionaire , thanks for the enlightening answer
Tschüss Teamplayer Fishtown
if you are looking for something let me know.Smiley KnipoogSmiley LOL
martymcfly
Bericht 13 van 26
12.777 Weergaven
Bericht 13 van 26
12.777 Weergaven
Great post. I needed that app as my drive died.
Thanks.
kyzarvs
Bericht 14 van 26
12.738 Weergaven
Bericht 14 van 26
12.738 Weergaven
Hi,
I've just reformatted a new Beast x10 laptop. The version of control center in the link here doesn't allow me to change the four RGB sections - I'd like them all one colour and they are currently R / G / B / lilac.
I realise the FN+ combos let me turn them off, but I'd like to be able to change them.
Thanks,
Joe
martymcfly
Bericht 15 van 26
12.733 Weergaven
Bericht 15 van 26
12.733 Weergaven
Funny enough I also cannot change the RGB on the Keyboard. I just thought it was the new Keyboard.
Glad it's not just me but I can't see anyway to fix this issue.
kyzarvs
Bericht 16 van 26
12.726 Weergaven
Bericht 16 van 26
12.726 Weergaven
Before I reformatted I had a vesion of the software that worked fine - I just presumed that I would be able to download it from the support website. Bit of a shame as I have to upgrade to W10 Pro for work, so couldn't keep the default W10 Home install.
Twm
Bericht 17 van 26
11.532 Weergaven
Bericht 17 van 26
11.532 Weergaven
would it be possible to do the same for my x7351?
I did have the control centre but it got wiped at the pc shop..
blue backlight really isn't doing it for me!
thanks!
Bericht 18 van 26
11.527 Weergaven
Bericht 18 van 26
11.527 Weergaven
Hello @Twm  and welcome,
are you sure you have an X7351 with a controller center?
bye Fishtown
Twm
Bericht 19 van 26
11.524 Weergaven
Bericht 19 van 26
11.524 Weergaven
Thank you! I'm not sure what it was called, however I could previously change the colours.
wishing I never took it into the shop really.
cheers!
Bericht 20 van 26
11.522 Weergaven
Bericht 20 van 26
11.522 Weergaven
Hi @Twm if the specification x7351 is correct please state your MSN number
bye Fishtown
25 ANTWOORDEN 25
