Medion Control Centre
25 RÉPONSES 25
Ikari_00
Message 1 sur 26
39 754 Visites
Message 1 sur 26
39 754 Visites
Hello, I recently purchased a refurbished Medion Erazer X7853 which has had its hard drives reformatted. As a result, I do not have the Medion Control Center installed onto my laptop which means that I cannot access the RGB keyboard. I have looked for a download link online but have not had any results. Would anyone be able to provide a download link to it? Thanks.
25 RÉPONSES 25
TPFLegionaire
Retired
Message 11 sur 26
34 884 Visites
Message 11 sur 26
34 884 Visites
hi @Ikari_00
Realy pleased to hear it has worked for you. this is great! Let us know if there is anything else we can do to help.
@Fishtown access is one thing, finding what you are lookingfor , now that is the challenge! Teamwork, community that is the key ,for if I fail, someone else will help and in this instance it was you @Fishtown ! Many thx.
Cheers!
TPFLegionaire
MEDION AG - A Lenovo Company • • Community: community.medion.com
Please reward helpful posts with Kudos and mark solutions with Accept as solution.
Message 12 sur 26
35 227 Visites
Message 12 sur 26
35 227 Visites
Moin @Ikari_00 ,
if the contribution is solved for you, mark it as such, thank you.
here again the direct link to the controll center: http://cdn.medion.com/downloads/treiber/ctrx785x_w10.exe
Teamworker@TPFLegionaire , thanks for the enlightening answer
Tschüss Teamplayer Fishtown
if you are looking for something let me know.Smiley clignant de l'œilSmiley MDR
martymcfly
Message 13 sur 26
12 753 Visites
Message 13 sur 26
12 753 Visites
Great post. I needed that app as my drive died.
Thanks.
kyzarvs
Message 14 sur 26
12 714 Visites
Message 14 sur 26
12 714 Visites
Hi,
I've just reformatted a new Beast x10 laptop. The version of control center in the link here doesn't allow me to change the four RGB sections - I'd like them all one colour and they are currently R / G / B / lilac.
I realise the FN+ combos let me turn them off, but I'd like to be able to change them.
Thanks,
Joe
martymcfly
Message 15 sur 26
12 709 Visites
Message 15 sur 26
12 709 Visites
Funny enough I also cannot change the RGB on the Keyboard. I just thought it was the new Keyboard.
Glad it's not just me but I can't see anyway to fix this issue.
kyzarvs
Message 16 sur 26
12 702 Visites
Message 16 sur 26
12 702 Visites
Before I reformatted I had a vesion of the software that worked fine - I just presumed that I would be able to download it from the support website. Bit of a shame as I have to upgrade to W10 Pro for work, so couldn't keep the default W10 Home install.
Twm
Message 17 sur 26
11 508 Visites
Message 17 sur 26
11 508 Visites
would it be possible to do the same for my x7351?
I did have the control centre but it got wiped at the pc shop..
blue backlight really isn't doing it for me!
thanks!
Message 18 sur 26
11 503 Visites
Message 18 sur 26
11 503 Visites
Hello @Twm  and welcome,
are you sure you have an X7351 with a controller center?
bye Fishtown
Twm
Message 19 sur 26
11 500 Visites
Message 19 sur 26
11 500 Visites
Thank you! I'm not sure what it was called, however I could previously change the colours.
wishing I never took it into the shop really.
cheers!
Message 20 sur 26
11 498 Visites
Message 20 sur 26
11 498 Visites
Hi @Twm if the specification x7351 is correct please state your MSN number
bye Fishtown
25 RÉPONSES 25
