My BIOS isn’t saving my keyboard lighting settings.
9 REPLIES 9
Thomas92Kr
Message 1 of 10
Message 1 of 10
Every time I reboot my laptop, my keyboard lighting settings are reset and I have to turn them off again in the BIOS. Is there a way to fix this?
Medion Erazer Beast X25 (MD62182)
2 ACCEPTED SOLUTIONS
Message 4 of 10
Message 4 of 10
Hi @Thomas92Kr
You can find the control center by entering your MSN number on the Medion service page:
https://www.medion.com/gb/service/product-detail/30033045
bye Fishtown
Message 8 of 10
Message 8 of 10
Hi @Thomas92Kr ,
the unzipped UWP App owns a .cmd commandline file, which is an executable file format, and I think it´s quite logical that you have no App to start unless you install thge App, isn´t it?
Anyhow, could you also please check the Microsoft store, cause for recent model series the ERAZER Control Center App is also rolled out via the store.
Feedbacuj very appreciated
9 REPLIES 9
Message 2 of 10
Message 2 of 10
Hello @Thomas92Kr  and welcome
briefly asked:
How do you exit the BIOS? just with esc = exit
or with F4 = save and exit?
Can't you also control/adjust the lighting in the control center?
bye Fishtown
GM7ZG7P: https://fccid.io/2AKHFAX200NG/User-Manual/AX200NGW-UserMan-5174928.pdf
Thomas92Kr
Message 3 of 10
Message 3 of 10
Hello @Fishtown thank you for your response. I always save and exit. And I’ve also done a clean Windows install after purchasing my laptop, so I don’t think I have an control center. I also can’t find anything about a control center in the manual.
Message 4 of 10
Message 4 of 10
Hi @Thomas92Kr
bye Fishtown
Thomas92Kr
Message 5 of 10
Message 5 of 10
Hi @Fishtown I've downloaded and installed the Control Center software however, I don't see an app I can launch. Untitled.png
I do see a RGBKeyboard reg file but I don't know what that will do when I register it.
Can you help me with this?
Message 6 of 10
Message 6 of 10
Hi @Thomas92Kr ,
I unfortunately have no such unit in hand, but having the Control Center/Gaming Center from both downloads from the MEDION service page correctly
you should have a Control Center/Gaming Center tray icon in your task bar.
Cheers
Thomas92Kr
Message 7 of 10
Message 7 of 10
Hi @Major_ToM I do not have a tray icon in my task bar.
I've only managed to install the 'Control Center Service Software MEDION ERAZER Beast X25'.
The 'Control Center UWP App MEDION ERAZER Beast X20/X25' does not have an executable that I can run.
Kind regards,
Thomas
Message 8 of 10
Message 8 of 10
Hi @Thomas92Kr ,
Thomas92Kr
Message 9 of 10
Message 9 of 10
@Major_ToM Thank you it worked!!
Message 10 of 10
Message 10 of 10
Awesome, @Thomas92Kr ! 🙂
9 REPLIES 9
