46039members
1678online
158058posts
How do I change the login to Windows 10?
The login to Windows 10 can be switched between Microsoft account or Local account.
To do this, open the settings with the key combination Windows + i and select Account. There you will find the button Sign in with a local account instead or Sign in with a Microsoft account instead, depending on the current setting.
The changed setting will be valid the next time you log on to Windows.
