46042members
2588online
158067posts
Why does my PC crash in hybrid mode with XMP activated?
When XMP is switched on, crashes may occur in combination with the hybrid mode of the Seasonic power supply unit.
⚠️The power supply unit must be switched off before the fan control is changed.⚠️
If the power supply unit has a fan control switch, set this to Normal mode. The fan does not rotate in hybrid or fanless mode (S³FC).
Explanation of the button settings
Switch position to Normal (two-stage mode):
Switch position to hybrid (three-stage mode):
Article in other languages:
Review Date: 2024-08-27
