FAQs about the MEDION X50+ SW Robot Vacuum Cleaner
Important notes on the organisation of stored maps for the MEDION X50+ SW Robot Vacuum Cleaner
  • My saved card can no longer be called up, what can I do?
  • If your saved map material can no longer be called up on the robot, the map material can be created and saved again by means of a new reconnaissance trip, taking into account the following steps, so that it can be restored, if it disappears again.
    1. Let the robot vacuum cleaner complete its exploration and set up no-go and no-mopping zones if necessary.
    2. Click on More (orange button with gear icon).
    3. Now select the menu item Change Map – the second-to-last option under Function Settings.
    4. If you haven't saved a map yet, a tab titled Current Map will be shown. Click on Save below the map on the right.
  • How can I restore created map material?
  • To load the saved map back into the app, click on the blue button in the Map 1 tab.
Version history
Last update:
‎04.01.2024 11:08
Updated by:
Labels (2)
Contributors
