46123members
1211online
158119posts
Why is the water not pumped out?
If the device does not pump out water, this may be due to a blocked strainer. The water then remains inside the appliance. First remove the strainer and clean it under running water. If a blocked strainer can be ruled out, pull the device forward a little and check whether the drain hose is kinked or crushed.
Article in other languages:
Review Date: 2022-11-19
