46102members
6769online
158119posts
How to reset a Nokia smartphone?
Reset Nokia smartphone with soft reset
Enter the code *#7780#. Then (if you are prompted) enter the start code 12345.
Reset Nokia smartphone with hard reset
If the problem persists, you should try a hard reset*.
Enter the code *#7370# on your Nokia phone. Then (if you are prompted) enter the start code 12345.
Follow the steps below to reset a non-working Nokia smartphone
Press On/Off + * + 3 until the Format option appears on the display.
*Important: Please note that a hard reset completely deletes all data, settings and content on your smartphone and resets it to the original factory settings.
ChangeLog:
Article in other languages:
Review Date: 2025-05-05
