Medion Life Smart TV P13958 39 MD 31358IT/156629.01 How Change DNS on smart tv ?
5 ANTWOORDEN 5
ronny941
Bericht 1 van 6
7.414 Weergaven
Bericht 1 van 6
7.414 Weergaven
hi
I have a problem with this smart tv
I can't understand how to change dns
has been set up like this:
192.168.001.014
instead of that:
192.168.1.14
and in the dns section I can't delete anything to make it 4 digit
how to solve the problem to change the DNS with google or cloudflare ?
thank you in advance
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
ronny941
Bericht 6 van 6
7.375 Weergaven
Bericht 6 van 6
7.375 Weergaven
to change the DNS I did this:
I went on the menu and then on the net tab and
after that I'm going to the advanced settings I changed from automatic to manual and I entered these values:
DNS server 1: "0001.0001.0001.0001"
DNS Server 2: "0001.0000.0000.0001"
so with the google dns was this:
DNS Server 1: 0008.0008.0008.0008
DNS Server 2: 0008.0008.0004.0004
at the end of the procedure I did save and everything worked correctly
5 ANTWOORDEN 5
ronny941
Bericht 2 van 6
7.400 Weergaven
Bericht 2 van 6
7.400 Weergaven
the dns settings they are set up like this:
"0000.0000.0000.0000"
how to change that to 1.1.1.1 or 1.0.0.1 ?
Gehringer
Retired
Bericht 3 van 6
7.390 Weergaven
Bericht 3 van 6
7.390 Weergaven
Hi @ronny941 and welcome to the Forum!
Could you please confirm that your TV MSN number is 30027375?
You should be able to find this code printed in a label located behind or underneath your product.
Regards,
Gehringer
ronny941
Bericht 4 van 6
7.382 Weergaven
Bericht 4 van 6
7.382 Weergaven
yes the number is correct
no matter I managed to change the dns
thank you all the same for your availability
Gehringer
Retired
Bericht 5 van 6
7.377 Weergaven
Bericht 5 van 6
7.377 Weergaven
Hi @ronny941,
I am pleased to know that you've managed it.
Could you please share with the other users what have you done to get this problem solved?
Regards,
Gehringer
ronny941
Bericht 6 van 6
7.376 Weergaven
Bericht 6 van 6
7.376 Weergaven
5 ANTWOORDEN 5
