Medion Life Smart TV P13958 39 MD 31358IT/156629.01 How Change DNS on smart tv ?
5 RÉPONSES 5
ronny941
Message 1 sur 6
7 416 Visites
Message 1 sur 6
7 416 Visites
hi
I have a problem with this smart tv
I can't understand how to change dns
has been set up like this:
192.168.001.014
instead of that:
192.168.1.14
and in the dns section I can't delete anything to make it 4 digit
how to solve the problem to change the DNS with google or cloudflare ?
thank you in advance
1 SOLUTION APPROUVÉE
Solutions acceptées
ronny941
Message 6 sur 6
7 377 Visites
Message 6 sur 6
7 377 Visites
to change the DNS I did this:
I went on the menu and then on the net tab and
after that I'm going to the advanced settings I changed from automatic to manual and I entered these values:
DNS server 1: "0001.0001.0001.0001"
DNS Server 2: "0001.0000.0000.0001"
so with the google dns was this:
DNS Server 1: 0008.0008.0008.0008
DNS Server 2: 0008.0008.0004.0004
at the end of the procedure I did save and everything worked correctly
5 RÉPONSES 5
ronny941
Message 2 sur 6
7 402 Visites
Message 2 sur 6
7 402 Visites
the dns settings they are set up like this:
"0000.0000.0000.0000"
how to change that to 1.1.1.1 or 1.0.0.1 ?
Gehringer
Retired
Message 3 sur 6
7 392 Visites
Message 3 sur 6
7 392 Visites
Hi @ronny941 and welcome to the Forum!
Could you please confirm that your TV MSN number is 30027375?
You should be able to find this code printed in a label located behind or underneath your product.
Regards,
Gehringer
ronny941
Message 4 sur 6
7 384 Visites
Message 4 sur 6
7 384 Visites
yes the number is correct
no matter I managed to change the dns
thank you all the same for your availability
Gehringer
Retired
Message 5 sur 6
7 379 Visites
Message 5 sur 6
7 379 Visites
Hi @ronny941,
I am pleased to know that you've managed it.
Could you please share with the other users what have you done to get this problem solved?
Regards,
Gehringer
ronny941
Message 6 sur 6
7 378 Visites
Message 6 sur 6
7 378 Visites
5 RÉPONSES 5
