LCD Monitor screen not displaying
1 ANTWOORD 1
tlims
Bericht 1 van 2
2.270 Weergaven
Bericht 1 van 2
2.270 Weergaven
Hello
Please I recently bout an lcd monitor display for my acer laptop. I have been using it for some weeks now as its fresh. This morning I worked with it and then later unplugged my laptop and went away. I came back this evening and i tried using the monitor, but it doesnt work. i turned it on and for some few seconds the monitor came on and then the display went off. i realized that the blue light after the power button is pressed immediately turns red. i have tried turning it on several occasions but still faced with the same issue even when i connect the hdmi cable still doesnt display anything.
I have tried the power reset and all but stil having same issue
Im using Medion Akoya (MD20152)
MSN: 30035681
Please anyone can help me?
1 ANTWOORD 1
Mastermind
Bericht 2 van 2
2.232 Weergaven
Bericht 2 van 2
2.232 Weergaven
Hi @tlims ,
could you please inform us, if your problem is still present, or if it has been solved in the meantime? Always a good option is to try different connections with different cables,or trying the display on a different laptop.
Cheers
1 ANTWOORD 1
