Caravan TV E12480 - select from EPG
2 REPLIES 2
jon
Message 1 of 3
Message 1 of 3
Does anyone know of a way to get the EPG to allow you to select the current channel when scrolling through the channels?
So far all we have been able to do is make a note of the channel number, exit the EPG and then manually type in the channel number. Surely there has to be a way of selecting the channel directly from the EPG?
I've checked the product page on here, but, there is no firmware update, so, maybe Medion could release one with a fix for this very annoying problem?
2 REPLIES 2
Message 2 of 3
Message 2 of 3
@jon
Hi Jon, usually you mark the Channel,better said the name of it ( egal. BBC)),  AMD press the OK  Key on the remote.
Cheerleader, daddle
jon
Message 3 of 3
Message 3 of 3
You would think that that is how it would work, but, it doesn't. I can move up and down channels, pages of channels, view daily and weekly guides, view programme info. The only thing that cannot be done is to select a programme to watch. I've pressed every key on the remote and nothing will select the programme to be watched.
2 REPLIES 2
