Medion lifetab p8314
31 ANTWORTEN 31
fioor
Nachricht 1 von 32
16.895 Aufrufe
Nachricht 1 von 32
16.895 Aufrufe
Hello! I have a trouble with installing update 2 on this tablet! Sorry for my band english! Here's photo of error!
https://postimg.org/image/nv0yarc7r/
31 ANTWORTEN 31
fioor
Nachricht 21 von 32
7.469 Aufrufe
Nachricht 21 von 32
7.469 Aufrufe
Hi @Luke, yes i saw the message and answer! I dont use xposed and i bought this tablet second hand
Nachricht 22 von 32
7.464 Aufrufe
Nachricht 22 von 32
7.464 Aufrufe
@daddle wrote:
@fioor
On the other hand, an error in /cache/recovery/block map happened more often whilest updating this tablet, so I guess it should be sent into service to get it reflashed with the complete firmware.
Regards, daddle
@Luke
Hi Luke,
I also wrote the second part, that a lot of users experienced an error in /cache/recovery/block map.
And I do not think that the old release keys (mp) shown in recovery could be a result of a restored backup   unwantedly by xposed, because this only would restore the old build prop in system, I guess.
Where gets the recovery the keys shown in the top-line from?  It`s not out of build. prop, because the file-system isn't mounted in recovery?
It's a miracle, different keys displayed  in recovery and in system. I am strongly interested to get to know how this was done.
Regards, daddle
Luke
Community Manager
Nachricht 23 von 32
7.458 Aufrufe
Nachricht 23 von 32
7.458 Aufrufe
Hello again @fioor & @daddle,
As I`ve mentioned before, the behaviour of this tablet while trying
to update it is leaving my colleagues a little bit puzzled, and your
latest replies don`t sound any better.
As Daddle has mentioned before, we would suggest to send the
tablet to our service for closer inspection.
@fioor: According to your personal data you`re not based in the
            EU, right? Any chance getting your device to someone who
            is living over here?
Regards,
Luke
fioor
Nachricht 24 von 32
7.455 Aufrufe
Nachricht 24 von 32
7.455 Aufrufe
@Luke, i live in Ukraine, Odessa! I dont have anyone who lives there(
Nachricht 25 von 32
7.113 Aufrufe
Nachricht 25 von 32
7.113 Aufrufe
@fioor
Hello floor,
is your problem solved by now through Medion.
Quite funny to find two different release keys in one tablet, in Recovery the MP key -> 0724.1420,
under settings - system - the keys from ota 1 -> 1009.1359
Medion announced inbetween the publishing of different firmware packages, for your P8314 also,
you willl find it on this page: https://www.medion.com/de/service/start/_product.php?msn=30019768&gid=00
Klick on Software.
regards, daddle
fioor
Nachricht 26 von 32
7.105 Aufrufe
Nachricht 26 von 32
7.105 Aufrufe
Hello, @daddle
Thanks for this solution, what i must to do with that files? Flash from fastboot?
Nachricht 27 von 32
7.094 Aufrufe
Nachricht 27 von 32
7.094 Aufrufe
@fioor
Firswt you must decide which Version you do need: Raydium or Samsung. I do not know the difference, and if there is one. Size of both is exactly the same
Then download the Recovery Guide for Android, everything will be explained in there.
regards, daddle
Luke
Community Manager
Nachricht 28 von 32
7.075 Aufrufe
Nachricht 28 von 32
7.075 Aufrufe
Hello @daddle,
Thank you for digging this up again.
@fioor:
Daddle is right. Please see this guide for further explaination:
Greetings,
Luke
fioor
Nachricht 29 von 32
7.065 Aufrufe
Nachricht 29 von 32
7.065 Aufrufe
Hello, @Luke
I install firmware on my tablet and it works good! Thanks to your's android team for firmware! I made all with command line, because i cant understand how to paste command --force! Thank you.
Nachricht 30 von 32
7.062 Aufrufe
Nachricht 30 von 32
7.062 Aufrufe
@Luke wrote:
Hello @daddle,
@fioor:
Greetings,
Luke
@Luke  Its for my pleasure. I do hate loose ends, although the mystery about the different release keys wasn't yet solved. :smileylol
@fioor
I told you,  after you questioning me in a PN, in my answer to you about how to flash the firmware with the
--force parameter ->  in an opened dos-box (cmd.exe) to insert the command flash.bat --force,  and you had to move with the dos-box path to your flashing folder with the firmware. And not just double-clicking the flash.bat.
And No, i have no idea if and how to install Windows on the P8314-model.
regards, daddle
31 ANTWORTEN 31
