I need your help: error in the last phase "finishing up" of Windows installation
1 ANTWOORD 1
Titeuf
Bericht 1 van 2
242 Weergaven
Bericht 1 van 2
242 Weergaven
Hello,
Windows 8.1 factory installation but under Windows 10 for years.
I tried to create a bootable key with Win8.1 and rufus because the Windows media tool no longer offers the installation of Win8.1. It does not work either.
I have a hard drive on the screen and a disk on the docking station.
The hard drive of the screen was formatted to accommodate an Android operating system but I do not use it anymore because it did not work very well.
I tried to format it via the command prompt(CMD: shift F10) and diskpart but it refuses the clean function and says access denied or error depends a little on its mood. In short It never stopped me from installing Windows on the docking station which worked very well.
Besides if someone knows how to clean and format the hard drive of the screen that would suit me because at the base it was the one that hosted Windows.
I tried by disabling secure boot, by disabling Bootfast.
Model Medion AKOYA : https://www.medion.com/gb/service/product-detail/30017739
Characteristics:
Processor: CPU Intel® Mobile Pentium® Quad-Core N3540 2,16 GHz
Memory: 4096 MB DDR3L (PC3-10600 / 1333 MHz)(onBoard)
BIOS/Chipsatz: AMI / Aptio5 1AREF017Support PnP & ACPI 5.0 Support external USB flash memory card boot up
Display: 15,6" (39,6 cm) Full HD (1920x1080) LED Backlight Multitouch AHVA-Full-HD-Display w/ IPS-Technologie(Advanced Hyper Viewing Angle)nonGlare
Graphics card: Intel HD Graphics (cpu integrated)
Optical drive: w/o Optical Device
Hard disk1: eMMC 64GB Hynix H26M78003BFRR FBGA169  (on the screen)
Hard disk2: HDD 500GB SATA ST500LT012
(On the docking station)
Sound card: Realtek ALC269Q-VC2-GR
Network: WLAN Intel AC3160 AC+BT PCIeMiniCard
Software1: MS WIN8.1 Std. Update 64b DVD ML CentralEU
Software2: S-DVD S6214T MD99440 Aldi ML
Also, i can speak french.
1 ANTWOORD 1
xAntho72x
Bericht 2 van 2
173 Weergaven
Bericht 2 van 2
173 Weergaven
Bjr,
Bcp bcp de détails 😄 néanmoins quelle est ton erreur ? Un visuel peut être ? Car en l’état difficile de t'apporter bcp d'assistance ^^
Cdt
1 ANTWOORD 1
