System restore files MD8875
3 REPLIES 3
pdenhond
Message 1 of 4
Message 1 of 4
The hard disk of my dad's Medion MD8875 crashed.  We have a backup of the data which we take every few months so that's not an issue.  Problem is that when i start the PC with F11 to reset it to factory defaults it says 'there is no factory image' because that part of the HD is damaged also.  I can insert a new compatible HD which i have but how to get the required restore files to be able to reset the system to factory state ?  (we don't need a new pc, by replacing the HD it's still a very good one but we should get the OS back on it)
3 REPLIES 3
Message 2 of 4
Message 2 of 4
@pdenhond
This is no problem, because the Windows key is stored in Bios, and the installation you get from Microsoft
-->  https://www.microsoft.com/de-de/software-download/windows10
With th etool you make a bootable USB installationstick , which willl install Windows on your new disk.
The key question you don't have to answer.
Sorry I only have the german page. Search for Windows 10 Iso in your browser.
Cheers, daddle
Message 3 of 4
Message 3 of 4
https://www.microsoft.com/en-gb/software-download/windows10
Message 4 of 4
Message 4 of 4
@Fishtown
Ja, en-gb. Ich hatte gb-gb, uk-gb und so weiter ausprobiert.
Andererseits können die Jungs ruhig mal Win10 Iso in ihren Browser eingeben. Wie ich es ihm geschrieben hatte.
Manchmal kommt es mir so vor , als ob wir den Usern noch das Klopapier hinterher tragen.
Das muss ja nicht sein, sicher nicht bei so leicht zu findenden Adressen.
3 REPLIES 3
