help required please
2 REPLIES 2
steve53
Message 1 of 3
Message 1 of 3
hi I require some help please.
I have a Medion laptop with an i5 7200u processor which apparently is not an approved processor for the windows 11 update.
upon trying to find alternative processors for the motherboard but I don't seem to be able to able to find any information about it. I used system information and CPU-Z and it says its a Medion F13K other information I can find is
system model S3409  MD60377.
any help information would be much appreciated.
Kind regards
Steve
2 REPLIES 2
Igor28
Message 2 of 3
Message 2 of 3
Hi @steve53 ,
Your i5-7200U is a BGA (Ball Grid Array) chip, which means it's soldered directly onto the motherboard.
This cannot be upgraded or replaced like a desktop CPU. Laptop motherboards are typically not compatible with other CPUs unless they were made for them — and even then, it's a big maybe.
So: swapping out the processor on your existing motherboard isn't feasible.
Your Options:
Option 1: Stay on Windows 10
  • Windows 10 is supported until October 14, 2025.
  • Perfectly usable and stable until then.
  • You can still get updates, security patches, etc.
  • No immediate need to upgrade unless you really want Windows 11.
Option 2: Install Windows 11 Anyway (Bypass CPU Check)
  • You can install Windows 11 on unsupported hardware.
  • Microsoft allows this, though you might miss out on some updates or support.
  • You just have to bypass the CPU check during installation.
steve53
Message 3 of 3
Message 3 of 3
HI @Igor28
thanks for your reply, Well that's a bugger then. so the choice is stay with an unsupported 10
or switch to an unsupported 11 seems like a catch 22 situation.
on the slightly plus side my main computer that's running a Ryzen 3 2200g looks like I can upgrade that.
So just need to check the wife's laptop now, not holding out a lot of hope for that either but we shall see.
2 REPLIES 2
