Medion display MSN 30007446 model MD 31522 PW
4 RÉPONSES 4
JDhome
Message 1 sur 5
2 666 Visites
Message 1 sur 5
2 666 Visites
When the display is turned on with the power switch, the power LED (blue color) starts blinking slowly. Also, nothing is displayed on the screen even though a signal is being received through the VGA port or the DVI-D port (tested with another display). Sometimes it happens that 'No signal' appears briefly on the screen. It also happens that there is a short flickering on the screen. After a period of 10 to 45 minutes, the image is displayed.
What is the possible cause and how can it be remedied?
I have already asked Medion to provide me with a copy of the electronic circuit diagram, but they keep claiming they don't have it.
Does anyone in the community have a copy of it? Where else can I find it?
4 RÉPONSES 4
Gehringer
Retired
Message 2 sur 5
2 661 Visites
Message 2 sur 5
2 661 Visites
Hi @JDhome ,
have you tried changing the cable?
Also, does your installation have any adaptors/converters or it is a direct connection PC -> Display via cable?
Regards,
Gehringer
JDhome
Message 3 sur 5
2 647 Visites
Message 3 sur 5
2 647 Visites
Thanks for your reply Gehringer
I have already tried with a different power cable.
And if the signal comes in through the VGA cable or the DVI-D cable, I have the same result.
No adapters / converters have been used.
regards,
JDhome
Gehringer
Retired
Message 4 sur 5
2 576 Visites
Message 4 sur 5
2 576 Visites
Hi @JDhome ,
it may be a hardware fault then.
Please contact your local Medion Technical Support team for further assistance.
Regards,
Gehringer
JDhome
Message 5 sur 5
2 547 Visites
Message 5 sur 5
2 547 Visites
Hi Gehringer
I'm also thinking of a hardwarefault.
That's why I asked the Community if anyone has a copy of the electronic circuit diagram of the diplay because  Medion keeps claming they do not have the electronic circuit diagram.
I wonder how Medion repairs this type of display without the electronic circuit diagram.
Does anyone have the electronic circuit diagram of the Medion display MSN 30007446 model MD 31522 PW ore does anyone know where I can find it?
Regards
JDhome
4 RÉPONSES 4
