Bluetooth not working.
8 ANTWOORDEN 8
SerialNo
Bericht 1 van 9
5.967 Weergaven
Bericht 1 van 9
5.967 Weergaven
I restored drivers from Intel and Bluetooth is not working ever since. I can see the Bluetooth icon into hiden Devices but not at start menu.
Anybody could help. Appreciate.
8 ANTWOORDEN 8
Bericht 2 van 9
5.960 Weergaven
Bericht 2 van 9
5.960 Weergaven
Hello @SerialNo
About what kind of device are we talking?
State the MSN number
bye Fishtown
SerialNo
Bericht 3 van 9
5.950 Weergaven
Bericht 3 van 9
5.950 Weergaven
Hello, Fishtown
Mi device is a MEDION AKOYA S15447 – MD62010 - MSN-30030297
Thank you
Bericht 4 van 9
5.923 Weergaven
Bericht 4 van 9
5.923 Weergaven
Hi @SerialNo
Your device was delivered without an operating system.
Can Bluetooth be found in the device manager under Bluetooth and network adapters? Uninstall the old drivers and install the ones from the driver package.
https://www1.medion.de/downloads/index.pl?op=detail&id=19992&type=treiber&lang=uk
Before that, you can try if you have set a restore point to see if you can activate it again.
Does WiFi actually work? If not, check whether flight mode is active (Fn+F2)
bye Fishtown
SerialNo
Bericht 5 van 9
5.912 Weergaven
Bericht 5 van 9
5.912 Weergaven
Hi, @Fishtown
This is what I've done:
- Open a new tab in chrome
- Write: https://www1.medion.de/downloads/index.pl?op=detail&id=19992&type=treiber&lang=uk
- All that opens is a ".txt" file, which explains how to install drivers. Not an application to execute.
What am I doing wrong?
I have wi-fi through a plug and play USB device. It does not work any other way. I've lost wi-fi with the bluetooth.
Thank you
SerialNo
Bericht 6 van 9
5.907 Weergaven
Bericht 6 van 9
5.907 Weergaven
Hi again, @Fishtown
Finally I was able to install the drivers you suggested. However, once restarting the computer, the same problem appeared again.
Before all this, a few months ago, I installed drivers from Intel in order to have wi-fi and bluetooth again. Well, ever since, no matter what I do, it hasn't been possible to delete the Intel(R) WI-FI 6 AX201 160Mhz.
I think I've done a nice mess... 😞
Bericht 7 van 9
5.897 Weergaven
Bericht 7 van 9
5.897 Weergaven
Hi @SerialNo
Remove the wireless card in Device Manager. Then restart the computer, it will now find the card again and want to reinstall it. Now tell him where you get the drivers from, namely from the driver package.
bye Fishtown
SerialNo
Bericht 8 van 9
5.893 Weergaven
Bericht 8 van 9
5.893 Weergaven
Hi, @Fishtown
I have removed the  wireless card in Device Manager a hundred times and restarted the computer but nothing seems to work. It always find the same controller from Intel (I downoaded the drivers from Intel web page itself ( https://www.intel.com/content/www/us/en/download-center/home.html ).
I don't dare to open the laptop to see the hardware inside.
Sorry to bother you so much. You have been very kind but I think I'll try to buy an usb device to have bluetooth.
Thank you so much for your help.
SerialNumber
SerialNo
Bericht 9 van 9
5.860 Weergaven
Bericht 9 van 9
5.860 Weergaven
Hi there, MEDION Community,
I'm sorry but I have been unable to solve the bluetooth and wi-fi problem following the kind advices suggested by @Fishtown.
Intel drivers must have some type of lock that prevents them from being uninstalled. Now I have both driver packages, Intel and Medion, but the PC only uses the Intel ones and I still haven't found the key to solution.
@SerialNumber
8 ANTWOORDEN 8
