update Bios MEDION B660M DS3H AX DDR4
3 ANTWOORDEN 3
xandera
Bericht 1 van 4
2.435 Weergaven
Bericht 1 van 4
2.435 Weergaven
Hello,
I am reaching out regarding the BIOS update for my MEDION B660M DS3H AX DDR4 computer. The MSN number of my device is 10024650.
Here are the details of my situation:
**  Currently, my motherboard is running a customized (OEM) BIOS, version 100, dated 2022.
**  I attempted to update the BIOS using the official BIOS from Gigabyte for the B660M DS3H AX DDR4 model, but the update fails with an "OEMID mismatch" error, indicating a compatibility issue between the customized BIOS and Gigabyte's official version.
**  I have not been able to find a specific BIOS update for my MEDION B660M DS3H AX DDR4 model on your support website, and I am unsure whether a compatible update exists.
I would like to know:
  • If a BIOS update specifically for my model is available.
  • Where I can download this update.
  • Whether it is possible to update my BIOS to an official version compatible with my system.
Thank you very much for your assistance and prompt response.
Best regards,
Xandera
3 ANTWOORDEN 3
tantos82
Bericht 2 van 4
2.020 Weergaven
Bericht 2 van 4
2.020 Weergaven
I am looking for the same thing. I have contacted Medion support. I need thin so i can upgrade my cpu to the 13th gen
Bericht 3 van 4
2.012 Weergaven
Bericht 3 van 4
2.012 Weergaven
Hi @tantos82 and welcome
What MSN number does your board have?
https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
bye Fishtown
Bericht 4 van 4
1.975 Weergaven
Bericht 4 van 4
1.975 Weergaven
@tantos82
The MSN Number of your PC should be  the same as  in Post 1 -->   the corresponding board's MSN is said as MSN 20069821 .
Check this number with the sticker on your Mainboard, except the MSN of your PC is indeed MSN 10024650 also.
Then for your PC the new Bios Version is 1.07 :
-->  https://cdn.medion.com/downloads/software/00_bios_ga_b660m_ds3h_ax.zip
  Follow this installation instructions:
-->  https://cdn.medion.com/downloads/anleitungen/BIOS_UPDATE_GIGABYTE_B660M_EN.pdf
Bye, daddle
3 ANTWOORDEN 3
