26.04.2025 11:44 - modifié 26.04.2025 12:03
i want to update my bios.
medion erazer specialist p10 MSN30033735.
divice manager doesnt do the job to update bios.
i have the version 1.07.04RME1 8/9/22
what is the latest bios version? i cant find nowhere.
le 30.04.2025 08:08
le 30.04.2025 08:08
Hi @loukaspsomas ,
We inform you that the BIOS version 1.07.04RME1 is still the recent version.
Regarding to the issue, It could be the CPU cooling paste (depending to the intensity of usage) which may have “disappeared” in the meantime and has to be replaced with a fresh one.
Kind regards
le 29.04.2025 14:49
le 29.04.2025 16:00
le 29.04.2025 16:00
Temperature of cpu is very high. 100c in gaming mode and normal mode 92.
I must to disable intel turbo boost in windows to got normal temp. I have windows 11
Also when i disable that option im loosing 2ghz. From 4,6ghz i got 2,xxghz.
Just wanna try new bios. Maybe is fix any of my problem, also maybe is more settings in bioe because in the version of bios that i have is limited the settings.
Thank you
le 29.04.2025 16:31
le 29.04.2025 16:31
Hi @loukaspsomas ,
I have requested a BIOS update from our technical support team. I will respond as soon as I receive feedback.
Kind regards
le 29.04.2025 16:37
le 30.04.2025 08:08
le 30.04.2025 08:08
Hi @loukaspsomas ,
Kind regards
