latest bios for medion earzer specialist p10 MSN30033735.
5 ANTWOORDEN 5
loukaspsomas
Bericht 1 van 6
2.764 Weergaven
Bericht 1 van 6
2.764 Weergaven
i want to update my bios.
medion erazer specialist p10 MSN30033735.
divice manager doesnt do the job to update bios.
i have the version 1.07.04RME1 8/9/22
what is the latest bios version? i cant find nowhere.
Tags (1)
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Igor28
Bericht 6 van 6
2.602 Weergaven
Bericht 6 van 6
2.602 Weergaven
Hi @loukaspsomas ,
We inform you that the BIOS version 1.07.04RME1 is still the recent version.
Regarding to the issue, It could be the CPU cooling paste (depending to the intensity of usage) which may have “disappeared” in the meantime and has to be replaced with a fresh one.
Kind regards
5 ANTWOORDEN 5
Igor28
Bericht 2 van 6
2.675 Weergaven
Bericht 2 van 6
2.675 Weergaven
Hi @loukaspsomas ,
Could you please inform us why you want to update the BIOS?
Kind regards
loukaspsomas
Bericht 3 van 6
2.670 Weergaven
Bericht 3 van 6
2.670 Weergaven
Temperature of cpu is very high.  100c in gaming mode and normal mode 92.
I must to disable intel turbo boost  in windows to got normal temp. I have windows 11
Also when i disable that option im loosing 2ghz. From 4,6ghz i got 2,xxghz.
Just wanna try new bios. Maybe is fix any of my problem, also maybe is more settings in bioe because in the version of bios that i have is limited the settings.
Thank you
Igor28
Bericht 4 van 6
2.658 Weergaven
Bericht 4 van 6
2.658 Weergaven
Hi @loukaspsomas ,
I have requested a BIOS update from our technical support team. I will respond as soon as I receive feedback.
Kind regards
loukaspsomas
Bericht 5 van 6
2.655 Weergaven
Bericht 5 van 6
2.655 Weergaven
Thanks.
Igor28
Bericht 6 van 6
2.603 Weergaven
Bericht 6 van 6
2.603 Weergaven
Hi @loukaspsomas ,
Kind regards
5 ANTWOORDEN 5
