cant find 105gb in my C: drive
6 ANTWOORDEN 6
ladicker1
Bericht 1 van 7
4.698 Weergaven
Bericht 1 van 7
4.698 Weergaven
I got a 237gb SSD on my laptop, and the only drive I got. I calculated all folders with their gb size and came up with a sum of 101gb. But it says that I only have 10 gb left. Where is everything else that takes up A WHOLE 126GB!?!?!?!?
gb whatsapp
6 ANTWOORDEN 6
Bericht 2 van 7
4.693 Weergaven
Bericht 2 van 7
4.693 Weergaven
@ladicker1
Hi ladicker, you should at least specify which PC you are speaking about. Please name the Brand, Model, the MSN number (it has 8 digits) and the MD number. On Medion Pcs or Laptops they are printed on a label on the bottom, or underneath the pc casing.
To properly check your disk setup you should post a screenshot from diskmanagement.
Jeevika
Bericht 3 van 7
4.010 Weergaven
Bericht 3 van 7
4.010 Weergaven
The 105GB of storage on your C: disk can be used up by system files or hidden files if you are unable to locate them. Consider utilizing disk cleanup tools or deleting pointless apps to find and free up space. To keep a system operating properly, good disk space management is crucial.
Bericht 4 van 7
3.855 Weergaven
Bericht 4 van 7
3.855 Weergaven
@angela72 @Jeevika
Both of you are referring to a  Post 1 1/2 old, and @ladicker1  didn''t even answer to my first reply from April 2022.
Second there are no hidden space consuming files on a C-Drive. In diskmanagement you find both , the size of your disk  plus the used amount of space.
Bericht 5 van 7
3.760 Weergaven
Bericht 5 van 7
3.760 Weergaven
@luis35
Nonsense.  Do read my post No. 4 And you can check the amount of space utilized in  diskmanagement.
Luke
Community Manager
Bericht 6 van 7
3.724 Weergaven
Bericht 6 van 7
3.724 Weergaven
Hi @daddle,
User #luis35 has been identified as Sleeper, post moved to internal.
Thx anyway,
Luke
amanda12
Sleeper
Bericht 7 van 7
3.216 Weergaven
Bericht 7 van 7
3.216 Weergaven
Locating missing storage on your C: drive can be like a digital treasure hunt. Check for large files, clear temporary files, and run disk cleanup. Utilize tools like WinDirStat for a visual breakdown. Reclaim that space and keep your system sailing smoothly.
6 ANTWOORDEN 6
