Windows Update - Erazer Logo Stuck on Boot
2 REPLIES 2
JonM
Message 1 of 3
Message 1 of 3
Since the latest windows update my gaming laptop is stuck on the erazer logo on boot. I can get to bios ok but that's it. I've tried all the usual media creation tool etc to no avail. I've researched and found that gigabyte laptops have a fix by reflashing the bios, something I want to try but need the files to do so, granted there are bios files to download from the medion downloads section for my laptop but that's installed / executed from windows, with windows running. I don't have that luxury so need the efi files to reflash bios. Reading posts it seems many are effected by this and 2 weeks into the issue there's still no remedy, I have a laptop paperweight. If any one has any ideas please let me know, to stress again, removing the battery, SSD etc does not fix this issue.
2 REPLIES 2
JonM
Message 2 of 3
Message 2 of 3
I've found the fix, got my laptop up and running again. On a usb stick, you need the Bootx64.efi file from the gigabyte link https://mcendon.github.io/gigabyte/BIOS_update_operation_instructions.pdf and the .BIN file for your laptop from the Medion website specific for your laptop / desktop. Startup BIOS and select run from file, from the usb select the Bootx64.efi and wait a minute for the system to start. When it does type fs0:
Then type the full name of your .BIN file and press enter.
Let the magic happen and windows will boot. Feel free to buy me a beer 😀
SpartacusBC
Message 3 of 3
Message 3 of 3
Please help!
I'm not great at this but have figured most of it out but cannot find the .Bin file for my laptop.
I have:
Medion Erazer Specialist P10
MD62447
MSN 30034002
Can anyone assist me please?
Thanks
2 REPLIES 2
