BIOS
1 REPLY 1
will716171
Message 1 of 2
Message 1 of 2
BIOS
Hiya,
I have a PC with the MSN of 10025141, its current BIOS is  B660H7W0X 107 / 23/02/2022 and im struggling to figure out how to update this. Im just upgrading my RAM to 32GB but currently it wont allow two 16GB cards and the BIOS is mostly locked.  Apologies if I could of found the answer elsewhere but the site is a little confusing
Tags (1)
1 ACCEPTED SOLUTION
Message 2 of 2
Message 2 of 2
@will716171
Hi Will
your Mainboard can take twice 32GB RAM.
If it doesn't work with your 16 GB modules, then you bought the wrong one. You shouldn't buy XMP moduls . They can not work in your board.
Those are the specs:
2 x 8 GB DDR4-SDRAM (PC4-25600 / 3200 MHz) Dual Channel Memory (2/2 Slots covered; 64 GB max.)
Regards, daddle
1 REPLY 1
Message 2 of 2
Message 2 of 2
@will716171
Hi Will
Regards, daddle
1 REPLY 1
