Need help
14 ANTWORTEN 14
Gadta89
Nachricht 1 von 15
5.131 Aufrufe
Nachricht 1 von 15
5.131 Aufrufe
Need help
Hello,
please medion help me with this. I realy need bios update to fix microcode.Cant find help with medion support no 1 help me.
14 ANTWORTEN 14
Gadta89
Nachricht 11 von 15
1.758 Aufrufe
Nachricht 11 von 15
1.758 Aufrufe
Big thank you to you!!!I hope to find fix I’m looking for  last 4 months.
RAZZ
Nachricht 12 von 15
1.719 Aufrufe
Nachricht 12 von 15
1.719 Aufrufe
hi @Gadta89 @Igor28 ,
As this was affected with this 13th/14th gen stability topic, this was solved with Bios 2.12 as mentioned in this Community FAQ
Currently 2.12 is the latest one which was available and successfully evaluated.
I hope this helps and solves your issue
thanks
tokareev_
Nachricht 13 von 15
1.492 Aufrufe
Nachricht 13 von 15
1.492 Aufrufe
Hey !
Im actually in the same sh*t than you bro… I recently bought an i7-13700F but it seems that my motherboard B660H7-M20 isn’t for 14th… I tried by multiple ways to Fix it, but as you said, we can’t update it by the BIOS… 😭 I tried with the Windows method, by the « cmd » but it still not working cause the security BIOS is actived and EVEN THIS we can’t disable from the BIOS.
Did you find a way for you ? You are maybe my only hope and way to fix it because nobody is talking about this problem…
(sorry for my bad english)
Gadta89
Nachricht 14 von 15
1.481 Aufrufe
Nachricht 14 von 15
1.481 Aufrufe
Hi mate,
https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
download . and follow instructions
ECS B660H7-M20 (MSN 20070914, 20071254) Version 2.12
tokareev_
Nachricht 15 von 15
1.395 Aufrufe
Nachricht 15 von 15
1.395 Aufrufe
Hello,
Unfortunately, i did everything right as it say by the « cmd » (run at admin),  this happened, but nothing changed… Well im losing hope.
14 ANTWORTEN 14
