Need help
14 RÉPONSES 14
Gadta89
Message 1 sur 15
6 766 Visites
Message 1 sur 15
6 766 Visites
Need help
Hello,
please medion help me with this. I realy need bios update to fix microcode.Cant find help with medion support no 1 help me.
14 RÉPONSES 14
Gadta89
Message 11 sur 15
2 364 Visites
Message 11 sur 15
2 364 Visites
Big thank you to you!!!I hope to find fix I’m looking for  last 4 months.
RAZZ
Message 12 sur 15
2 325 Visites
Message 12 sur 15
2 325 Visites
hi @Gadta89 @Igor28 ,
As this was affected with this 13th/14th gen stability topic, this was solved with Bios 2.12 as mentioned in this Community FAQ
Currently 2.12 is the latest one which was available and successfully evaluated.
I hope this helps and solves your issue
thanks
tokareev_
Message 13 sur 15
2 098 Visites
Message 13 sur 15
2 098 Visites
Hey !
Im actually in the same sh*t than you bro… I recently bought an i7-13700F but it seems that my motherboard B660H7-M20 isn’t for 14th… I tried by multiple ways to Fix it, but as you said, we can’t update it by the BIOS… 😭 I tried with the Windows method, by the « cmd » but it still not working cause the security BIOS is actived and EVEN THIS we can’t disable from the BIOS.
Did you find a way for you ? You are maybe my only hope and way to fix it because nobody is talking about this problem…
(sorry for my bad english)
Gadta89
Message 14 sur 15
2 087 Visites
Message 14 sur 15
2 087 Visites
Hi mate,
https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
download . and follow instructions
ECS B660H7-M20 (MSN 20070914, 20071254) Version 2.12
tokareev_
Message 15 sur 15
2 001 Visites
Message 15 sur 15
2 001 Visites
Hello,
Unfortunately, i did everything right as it say by the « cmd » (run at admin),  this happened, but nothing changed… Well im losing hope.
14 RÉPONSES 14
