Need help
14 ANTWOORDEN 14
Gadta89
Bericht 1 van 15
6.854 Weergaven
Bericht 1 van 15
6.854 Weergaven
Need help
Hello,
please medion help me with this. I realy need bios update to fix microcode.Cant find help with medion support no 1 help me.
14 ANTWOORDEN 14
Gadta89
Bericht 11 van 15
2.379 Weergaven
Bericht 11 van 15
2.379 Weergaven
Big thank you to you!!!I hope to find fix I’m looking for  last 4 months.
RAZZ
Bericht 12 van 15
2.340 Weergaven
Bericht 12 van 15
2.340 Weergaven
hi @Gadta89 @Igor28 ,
As this was affected with this 13th/14th gen stability topic, this was solved with Bios 2.12 as mentioned in this Community FAQ
Currently 2.12 is the latest one which was available and successfully evaluated.
I hope this helps and solves your issue
thanks
tokareev_
Bericht 13 van 15
2.113 Weergaven
Bericht 13 van 15
2.113 Weergaven
Hey !
Im actually in the same sh*t than you bro… I recently bought an i7-13700F but it seems that my motherboard B660H7-M20 isn’t for 14th… I tried by multiple ways to Fix it, but as you said, we can’t update it by the BIOS… 😭 I tried with the Windows method, by the « cmd » but it still not working cause the security BIOS is actived and EVEN THIS we can’t disable from the BIOS.
Did you find a way for you ? You are maybe my only hope and way to fix it because nobody is talking about this problem…
(sorry for my bad english)
Gadta89
Bericht 14 van 15
2.102 Weergaven
Bericht 14 van 15
2.102 Weergaven
Hi mate,
https://community.medion.com/t5/FAQs/How-do-I-optimize-the-stability-of-my-desktop-PC-with-an-Intel/...
download . and follow instructions
ECS B660H7-M20 (MSN 20070914, 20071254) Version 2.12
tokareev_
Bericht 15 van 15
2.016 Weergaven
Bericht 15 van 15
2.016 Weergaven
Hello,
Unfortunately, i did everything right as it say by the « cmd » (run at admin),  this happened, but nothing changed… Well im losing hope.
14 ANTWOORDEN 14
