am 08.01.2025 19:09
am 08.01.2025 19:09
I bought a pre built gaming pc about a week ago. MEDION Erazer Bandit P20 Gaming PC - Intel® Core™ i7, RTX 4060 Ti, 1 TB SSD from currys. It has the motherboard i specified above but I cant find a way to update bios so my CPU doesn't get damaged. The bios version I'm on is 760H7EMW0X.207, 24/02/2024 and I am aware the patch for the issue was released at a later date than this. So how would I go about updating the bios as I can find almost nothing about this motherboard online and no information about updating bios for this board.
am 13.01.2025 09:35
am 13.01.2025 09:35
Having the same issue.
MEDION B760H7-EM motherboard with 17-13700 CPU.
All I've been able to find is this one page PDF, which does not work: https://cdn.medion.com/downloads/anleitungen/BIOS_UPDATE_ECS_B760H7-EM_EN.pdf
Uragg.
am 14.01.2025 21:33
am 14.01.2025 21:33
Même problème, elle semble fabriquée par ECS - carte B760h7-M20.
Mais pas de BIOS téléchargeable sur leur site non plus.
Medion semble bloquer la carte avec leur BIOS et il est impossible d'ajuster les fréquences RAM ( 150euros à la poubelle).
Fréquences bridées à 4400 alors que la carte peu aller à 5600
am 14.01.2025 21:40
am 20.01.2025 22:48
am 20.01.2025 22:48
Bonjour @djo0007 et bienvenue
, une mise à jour du BIOS peut être trouvée ici :
https://www.medion.com/fr/service/product-detail/10025101
hello @Sausageroll62 and welcome
you have a bios 760H7EMW0X.207, 24/02/2024 .
BIOS 2.09 should also work there:
https://www.medion.com/gb/service/product-detail/10025101
au revoir/bye Fishtown
ReleaseNote.text
Model Name: B760H7-EM BIOS Version/Date:760H7EMW0X209 / 2024.09.28
BIOS Name:B760H7-EM_BIN.Bin BIOS Checksum:2751h
UEFI GOP Version:17.0.1079 VBIOS Version:N/A
UEFI LAN Driver: 2.059 Legacy LAN ROM:N/A
UEFI iRST/RAID Version:19.5.0.8676 iRST/RAID Version:19.5.0.8676
MicroCode/Agesa:
M0790672_00000032
M32B0671_0000012B
MRC/FRC Version:0.0.4.184 SiC Version:0C.00.BA.10 (4301.01)
ME Version:16.1.30.2255 AmiCoreBase:1AYRT_048
Firmware GUID (BIOS):D115C097-1C07-49dd-870A-E3EE6D7DC902
ME Update:No
Modified:
Base on 208
1. Add SA50158_Supplement patch for vulnerabilities;
2. Add PLDM module.
3. Update MCU from M32B0671_0000011D.pdb to M32B0671_0000012B.pdb;
4. Update AFU tool from v5.15.01.0075 to v5.16.03.0120 in BIOS package;
5. Fixed BIOS 208 WU update issue.
Model Name: B760H7-EM BIOS Version/Date:760H7EMW0X208 / 2024.07.01
BIOS Name:B760H7-EM_BIN.Bin BIOS Checksum:C183h
MicroCode/Agesa:
M0790672_00000032
M32B0671_0000011D
ME Update:No
Modified:
Base on 207
1. Adjust ERAZER logo resolution to 1024*768;
2. Add logofail patch;
3. Set "Re-Size BAR Support" default value to Enabled;
4. Add ReleaseNote.txt in BIOS package;
Model Name: B760H7-EM BIOS Version/Date:760H7EMW0X207 / 2024.02.24
BIOS Name:B760H7-EM_BIN.Bin BIOS Checksum:425Ah
MicroCode/Agesa:
M0790672_00000032
M32B0671_0000011D
ME Update:No
am 23.01.2025 11:03
am 23.01.2025 11:03
Good morning, I'm having issues updating the bios in my Medion PC.
Specs: Item: Medion Engineer X32 Gaming PC, Intel Core i7-13700, 16GB RAM, 1TB SSD, NVIDIA GeForce RTX 4070, Windows 11 Home
I have followed the link in your previous comment, ran CMD as administrator and receive this error:
| AMISCE Utility. Ver 5.05.08.0009 |
| Copyright (c) 2023 AMI. All rights reserved. |
10 - Error: Unable to load driver.
C:\Users\elevynn\Downloads\00_Bios_b760h7-em_v2>SPG0ECString.exe log.txt "Enable VMD controller"
?????: log.txt
C:\Users\elevynn\Downloads\00_Bios_b760h7-em_v2>if not exist log.txt goto Double
C:\Users\elevynn\Downloads\00_Bios_b760h7-em_v2>echo Please reboot computer and try again!
C:\Users\elevynn\Downloads\00_Bios_b760h7-em_v2>Pause
Press any key to continue . . . I have tried to enable the VMD controller in BIOS, however my drive does not then boot.
Do you have any advice?
Thanks,
Uragg.
am 31.01.2025 15:48
am 31.01.2025 15:48
Hi Uragg,
I have the same trouble. The PC doesn't reboot after enabling the VDM Controller (the famous blue screen).
The upgrade is importants for the stability, seems that MEDION support has some issues.
Good luck
Daniel
18.02.2025 09:59 - bearbeitet 18.02.2025 10:00
Bonjour,
Je suis dans le meme cas . Je ne comprends pas pourquoi ils n'ont pas un système similaire aux autres.
Les commandes ne fonctionnent pas.
am 18.02.2025 10:26
am 18.02.2025 10:26
Hi Uragg
Did you found a solution? Because i have the same problem as you. And support are not here for help visibly.
Thanks.
am 18.02.2025 12:02
am 18.02.2025 12:02
C'est un souci avec une configuration dans le bios. Malheureusement après modification, le PC ne démarre plus, un bel écran bleu.
Et le support est inexistant, ils se cachent leur incapacité derrière des demande de numéro de série, facture, etc...
Bonne chance
