Control Centre
10 REPLIES 10
TOMO
Message 1 of 11
Message 1 of 11
Control Centre
I have a ERAZER X17805 That crashed and would not restart even on Windows recovery. cut a long story short had to reinstall windows from scratch. the problem is where do i find Medion Control Center for this laptop. Looked everywhere but no luck
Tags (1)
1 ACCEPTED SOLUTION
Message 6 of 11
Message 6 of 11
hello @TOMO
please have a look in the uefi setting under "advanced" to see if you have the entry:" keyboard backlight features".
There you can turn off the light or set that you want to decide only after the start (select keyboard light mode when power on)
bye Fishtown
10 REPLIES 10
Message 2 of 11
Message 2 of 11
Hi @TOMO and welcome,
www1.medion.de/downloads/index.pl?op=detail&id=20103&type=treiber&lang=uk
bye Fishtown
what is your MSN number!
TOMO
Message 3 of 11
Message 3 of 11
HI Fishtown
My MSN 30026622
MD 61443
ERAZER X17805
Message 4 of 11
Message 4 of 11
Hi @TOMO
test Gaming Center:
www1.medion.de/downloads/index.pl?op=detail&id=21206&type=treiber&lang=uk
Bye Fishtown
TOMO
Message 5 of 11
Message 5 of 11
Its the control center software that I'm looking for mainly to turn the lights off on the keyboard
Message 6 of 11
Message 6 of 11
hello @TOMO
bye Fishtown
TOMO
Message 7 of 11
Message 7 of 11
Hi what do you mean by uefi setting?
Message 8 of 11
Message 8 of 11
Hi @TOMO
it used to be called bios.
Look page 36
bye Fishtown
If "F2" doesn't work, try "DEL"
edit: from page34 "Notebook manual", https://usermanual.wiki/TONGFANG/9560NG.9560NGW-UserMan
TOMO
Message 9 of 11
Message 9 of 11
Thanks, this worked set keyboard lights in bios.
boyscout
Message 10 of 11
Message 10 of 11
Hi!
Can I please get a download link for control center for my medion erazer p15607 msn 30028132? Thank you!
10 REPLIES 10
