Medion e4241 Audio problem
2 REPLIES 2
mladenking94
Message 1 of 3
Message 1 of 3
Hello all,
I have a Medion E4241, after reinstalling Windows 10 audio does not work.
Can you help me somehow?
Before reinstallation everything worked neatly.
Is there a problem with the settings driver or bios?
2 REPLIES 2
mladenking94
Message 2 of 3
Message 2 of 3
Camrin
Message 3 of 3
Message 3 of 3
Hello,
Quite the same with my Medion E4241. I have the sound only for 10-15 minutes after a fresh start and then it is lost. So I have to reboot it all the time. Is it a Winwods 10 issue only? As far as I know, an Audio chipset has a specific PNP ID that should match the one in the driver file, right?
Camrin
essaytyper.pro
2 REPLIES 2
