Bios update
3 REPLIES 3
Jnr
Message 1 of 4
Message 1 of 4
Bios update
how do I update my Medion ms-7708 BIOS
3 REPLIES 3
RAZZ
Message 2 of 4
Message 2 of 4
Hi @Jnr
what model of unit do you have, MSN number, and current version of the BIOS?
with this info someone will be able to assist
thanks
jkfirst
Message 3 of 4
Message 3 of 4
Hello everybody,
 My screen don't show any image. It is completely dark. My fans turn on, the indicator lights get on but the Screen does not show anything. I have tried all the shortcuts to start it with no positive result. I have been told to find the BIOS in other to reboot my system with the USB but i don't know where to fine the BIOS. Here ere some references of my Medion laptop:
MSN30035906
XU133T REV 4.0 A
Thanks for your reply
RAZZ
Message 4 of 4
Message 4 of 4
dear @jkfirst
Have you tried your unit with an external screen to eliminate the screen being faulty?
this is your unit MSN 30035906 MEDION AKOYA E16423 (MD 62559) DE
The Bios can be accessed on boot by pressing F2 to find current version and see if any updates are available.
thanks
3 REPLIES 3
