BIOS update folder in medion website not complete
15 ANTWOORDEN 15
paulmaindivide
Bericht 1 van 16
14.051 Weergaven
Bericht 1 van 16
14.051 Weergaven
Hello
Following a problem of Blue screen I want to update my BIOS to make sure it's not related to this.
When I go this page https://www.medion.com/gb/service/product-detail/30035597 and click on the info button it describes the process as such :
However in the folder they give there isn't file called FF in the folder BIOS... And when I try to launch the FF.inf that is in the folder EC I have this error message
I really don't what to do
15 ANTWOORDEN 15
Mastermind
Bericht 11 van 16
5.344 Weergaven
Bericht 11 van 16
5.344 Weergaven
Hi all,
@paulmaindivide :Maybe you could comment, if you are still experiencing any kind of trouble with the unit, or are the problems solved?
@Nomi613: Can you please exactlylist, which steps you exactly too, to install the EC update?
Cheers
Another tip: To mention a community user so that they are notified when you reply, write an @ sign in front of their name (e.g. @Major_Tom)
Nomi613
Bericht 12 van 16
5.342 Weergaven
Bericht 12 van 16
5.342 Weergaven
Hello, the first part in the "Bios" folder went well, it's on the second part that I have a problem, when I try to run the INF in the "EC" folder, I get the same error message as the person who posted the topic.
paulmaindivide
Bericht 13 van 16
5.329 Weergaven
Bericht 13 van 16
5.329 Weergaven
Hello
I have the exact problem as Nomi, I was able to do the first step with the file FlashWinX64.bat which went well, and then I tried to execute the ff.inf file and I had the certificate error message.
Nomi613
Bericht 14 van 16
5.310 Weergaven
Bericht 14 van 16
5.310 Weergaven
if anyone has a solution that would be great
Nomi613
Bericht 15 van 16
5.306 Weergaven
Bericht 15 van 16
5.306 Weergaven
I've found a solution,
open the "EC" folder, go to "ECWinFlash", then run ECWinFlash, once this is done, choose the ROM "V15_7xRNC.06ME2a" in the EcWinFlash folder and click on "Flash".
It worked perfectly for me 🙂
Cocooo
Bericht 16 van 16
5.249 Weergaven
Bericht 16 van 16
5.249 Weergaven
Hi,
i have blue screen also, does the bios update changed it?
15 ANTWOORDEN 15
