medion akoya e7225 won't start
2 REPLIES 2
omarbhd
Message 1 of 3
Message 1 of 3
Hello, I have a medion akoya e7225 that have no signs of life apart from small clics when i plug the charger in,
please help!
1 ACCEPTED SOLUTION
omarbhd
Message 3 of 3
Message 3 of 3
Hi @Gehringer thank you very much for your reply but i just found the problem,it was a ram issue.
2 REPLIES 2
Gehringer
Retired
Message 2 of 3
Message 2 of 3
Hi @omarbhd and welcome to the FORUM!
Does the led charging light switch on?
If it does not, can you try with a different charger?
If none of the troubleshooting works, I believe you will need to contact your local Medion technical support team
Regards,
Gehringer
omarbhd
Message 3 of 3
Message 3 of 3
2 REPLIES 2
