Medion Akoya E6215 Help Request
1 REPLY 1
nunomgnunes
Visitor
Message 1 of 2
Message 1 of 2
Good evening, I bought a used medion akoya e6215 (MD97689) with MSN: 30011961 and wanted to know if there is any way to put wifi without active on the linux system boot without having to be using the FN + F2 keys all the time and since on windows 10 i installed a hotkey and it works well and also wanted to know if i can change the cpu that comes with the pc (Pentium P6100 and if i can change an i7-640M) and there is a bios updtae since the site does not find none, thank you very much
1 REPLY 1
Gehringer
Retired
Message 2 of 2
Message 2 of 2
Hi @nunomgnunes ,
unfortunately we can only support products on its original condition but maybe the community will be able to help you!
Are there any Linux experts out there?
Regards,
Gehringer
1 REPLY 1
