Windows not loading.
1 REPLY 1
ZARDOZ
Message 1 of 2
Message 1 of 2
I press the power button and the power light comes on. It starts to boot and then I get a dark screen with a flashing command cursor in top left. I can't type anything or do anything. Tried holding down F10 when booting but I get a repeated fast beep. I have a recovery disk but can;t access it. What do I do please?
1 REPLY 1
Message 2 of 2
Message 2 of 2
@ZARDOZ
Without knowing about which or what PC you are talking about nobody will be able to really help you.
Please name your Medion MD-Number asnd the MSN-Number.
I should try to start Windows with the F2-Button pressed! This will open the UEFI-Bios, where you will be able to select the Boot-Device, eg the harddisk (SSD), if your device is a Windows-PC.
1 REPLY 1
