S6214T 2in1 laptop battery & charging question
4 ANTWOORDEN 4
JamesGordon55
Bericht 1 van 5
5.355 Weergaven
Bericht 1 van 5
5.355 Weergaven
Hi,
I'm looking at a purchase of S6214T as they seem to be just what I need.
I found information here https://fr.ifixit.com/R%C3%A9ponses/Afficher/453548/Why+isn%27t+my+laptop+charging
that the tablet part (screen) has its own charging port, is that true?
Also/alternatively, which battery in Medion serviceshop is the one for the tablet part?
1) MSN: 40049195
Battery, 3 cells, 11.4 Volt, 3355 mAh
or
2) MSN: 40049196 Battery, 2 cells, 7.4 Volt, 4150 mAh
Thanks a lot 🙂
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Bericht 2 van 5
5.349 Weergaven
Bericht 2 van 5
5.349 Weergaven
@JamesGordon55
Hi, I do not own a S6214T, but I can help you a little bit further. First there are two Models S6214T NBs;
one with the MD  99380; and second MD 99440; the second is from Summer 2014, the first from begin 2014.
The different models are basically the same. You will find infos in this manual;
http://download2.medion.com/downloads/anleitungen/bda_40049657.pdf
Look on page 16 ff for views: Indeed there are three charging points, one in the lower edge of the tablet, one in the connect X-modul in the left-hand aisle, and the third in the rear side of the base.
If you charge in the left-side aisle of the ConnectX Modul or in the rear-side of the base unit, with connected tablet you will charge both parts, base and tablet. The mains adapter connected to the tablets charging socket can of course charge the tablet on its own only.
There is a switch on the mains adapter, this must be set to "I" or "On".
But seeing the model is about 4 to 5 year sold, many of the batteries are down by now.
If you plan to swap batteries by yourself, I would open the base and check for the number, wether it is
MSN 40049195  Battery with 3 cells, 11.4 Volt, 3355 mAh,  or  MSN: 40049196 with two cells, 7.4 Volt, 4150 mAh.
But if you have the MSN-Number of the whole S6214T (its on a label on the bottom of the base), please post it here.
Than we although can differentiate which model is yours. Also the MD-Number, please.
 Regards, daddle
4 ANTWOORDEN 4
Bericht 2 van 5
5.350 Weergaven
Bericht 2 van 5
5.350 Weergaven
@JamesGordon55
 Regards, daddle
JamesGordon55
Bericht 3 van 5
5.343 Weergaven
Bericht 3 van 5
5.343 Weergaven
Wow, great product AND great community 🙂
I will get my hands on one beginning of next week, and so will my friend.
I suspect the battery life considering release date may be an issue, hence those questions, but I am reassured now. I can live with keeping it charged from mains as well.
Bericht 4 van 5
5.325 Weergaven
Bericht 4 van 5
5.325 Weergaven
@JamesGordon55
Hello, be aware, some convertibles with a tablet are very sensitiv with current support by mains going through the battery, and do not work if the battery is down and the charging-circuit blocks charging to prevent a battery run-away.
This is because with tablets all energy goes and comes through the accumulator, there is no bypass for the mains connection. How this works with this model and  if two batterys are involved like with the additional battery in the base-unit I do not know, but I guess it is similar.
Regards, daddle
JamesGordon55
Bericht 5 van 5
5.198 Weergaven
Bericht 5 van 5
5.198 Weergaven
Hi daddle,
Thank you for answer.
Just to be clear, in laymans terms, this means that if the battery in tablet is nearing its demise, the mains connection may not work either - correct? (my model S6214T only has the tablet battery installed, and 2 mains connectors - in tablet, and in the hinge).
4 ANTWOORDEN 4
