Original BIOS Akoya P6687 - MD61006
30 ANTWOORDEN 30
kuro2
Bericht 1 van 31
12.874 Weergaven
Bericht 1 van 31
12.874 Weergaven
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
30 ANTWOORDEN 30
javigom
Bericht 11 van 31
3.456 Weergaven
Bericht 11 van 31
3.456 Weergaven
I'm going to tell what happened. As you know, version 207 of the bios is incompatible with Linux and that is why I got version 209, but when I installed it, the computer stops detecting the audio devices and the graphics card (which in my case is an MX150). I've tried installing both clean Linux and Windows and they don't work.
heywire2
Bericht 12 van 31
3.447 Weergaven
Bericht 12 van 31
3.447 Weergaven
javigom
Bericht 13 van 31
3.445 Weergaven
Bericht 13 van 31
3.445 Weergaven
I've tried tried to communicate in many ways with them but they do not give me a solution, if you could upload the bios I would appreciate it
heywire2
Bericht 14 van 31
3.441 Weergaven
Bericht 14 van 31
3.441 Weergaven
Sure, here you are: https://we.tl/t-MlqfufhgZu
javigom
Bericht 15 van 31
3.436 Weergaven
Bericht 15 van 31
3.436 Weergaven
Hi,
When I try to install it, it appears a message saying: "This BIOS is not for your Notebook PC." What should I do?
javigom
Bericht 16 van 31
3.406 Weergaven
Bericht 16 van 31
3.406 Weergaven
Does anyone know how to fix it? My MSN is 30024225
Bericht 17 van 31
3.396 Weergaven
Bericht 17 van 31
3.396 Weergaven
@javigom
You arte sure you have the same version Windows installed as at the time the Biosfile  was published?
Your battery is at least 50% charged, and power supply is attached? Start the update with rightclick as an admin.
Regards, daddle
javigom
Bericht 18 van 31
3.388 Weergaven
Bericht 18 van 31
3.388 Weergaven
@daddle
No, I have the last update of Windows (20H2). What version of windows should I have?
Greetings
Bericht 19 van 31
3.386 Weergaven
Bericht 19 van 31
3.386 Weergaven
@javigom
This I do not know exactly.  It depends on which date you bought your PC, and the date of when the Bios was published.
Similar PCs with the naming P6687 were sold wit Win 10; so I think your Win 10 is oK.
I just gave you some general rules.
javigom
Bericht 20 van 31
3.379 Weergaven
Bericht 20 van 31
3.379 Weergaven
@daddle
So there is no solution? Medion technical service does not respond to me ...
30 ANTWOORDEN 30
