on 17.07.2018 12:33
on 17.07.2018 12:33
Hello.
Can you send me original bios installer for Akoya P6687 - MD61006, to restore my computer?
Many thanks.
on 17.02.2021 18:44
on 17.02.2021 18:44
on 17.02.2021 19:00
on 17.02.2021 19:00
Use this: https://www.medion.com/es/service/product-detail/30024215?fromTopicsPage=true
If not, tell me and I reupload the bios
on 17.02.2021 19:05
on 17.02.2021 19:05
I've tried tried to communicate in many ways with them but they do not give me a solution, if you could upload the bios I would appreciate it
on 17.02.2021 19:11
on 17.02.2021 19:17
on 17.02.2021 19:17
Hi,
When I try to install it, it appears a message saying: "This BIOS is not for your Notebook PC." What should I do?
on 18.02.2021 22:44
on 18.02.2021 22:44
Does anyone know how to fix it? My MSN is 30024225
on 19.02.2021 06:05
19.02.2021 09:19 - edited 19.02.2021 09:20
on 19.02.2021 09:46
on 19.02.2021 09:46
This I do not know exactly. It depends on which date you bought your PC, and the date of when the Bios was published.
Similar PCs with the naming P6687 were sold wit Win 10; so I think your Win 10 is oK.
I just gave you some general rules.
on 19.02.2021 10:05
