Need storage drivers for Erazer gaming notebook x7857
15 ANTWORTEN 15
Kikiriki
Nachricht 1 von 16
2.115 Aufrufe
Nachricht 1 von 16
2.115 Aufrufe
Hello i have the erazer x7857 and i need the storage drivers so i can install tiny11 because while installing windows 11 my whole system32 deleted itself and im on manjaro linux right now and it sucks. So i wanna install tiny11 on my laptop but i need storage drivers can someone please find them for me
Kikiriki
Nachricht 14 von 16
1.610 Aufrufe
Nachricht 14 von 16
1.610 Aufrufe
I dont need storage drivers anymore cause i downloaded win11 on a usb i bought new (old one broke) and now im using windows 11
15 ANTWORTEN 15
Nachricht 2 von 16
1.366 Aufrufe
Nachricht 2 von 16
1.366 Aufrufe
hi @Kikiriki and welcome
You can find the existing drivers by entering x7857 on the Medion service page. It is more precise if you enter the MSN number there.
https://www.medion.com/gb/service/product-detail/30025546
bye Fishtown
Kikiriki
Nachricht 3 von 16
1.345 Aufrufe
Nachricht 3 von 16
1.345 Aufrufe
Hi Fishtown
These are regular drivers and i need storage drivers i dont need drivers for intel and Nvidia
Nachricht 4 von 16
1.335 Aufrufe
Nachricht 4 von 16
1.335 Aufrufe
Hi @Kikiriki
Then you should go to the manufacturer's website where the memory comes from (which you haven't mentioned by name yet).
bye Fishtown
Nachricht 5 von 16
1.285 Aufrufe
Nachricht 5 von 16
1.285 Aufrufe
@Kikiriki
Why is talked about storage drivers for memory? Tiny 11 is a reduced Windows 11 version for installation, only 3.7 GB against 6,5 GB install medium volume of normal Windows. With a lot of garbage left out, (That is what they say)
@Kikiriki schrieb:
Hello i have the erazer x7857 and i need the storage drivers so i can install tiny11 because while installing windows 11 my whole system32 deleted itself and im on manjaro linux right now and it sucks. So i wanna install tiny11 on my laptop but i need storage drivers can someone please find them for me.
@Kikiriki
Please  tell me what is the difference between storage drivers an the Intel drivers? Which report talks about "storage drivers"?
I only can image Intels RST drivers are meant. And what about the chipset drivers? Which you have to install firrst. Therefor you do need the original ones first.
Also there could be a  a general incompatibility between your device and tiny 11. Read at XDA devlopers.com
--> https://www.xda-developers.com/tiny11-hands-on/
cheers, daddle
Kikiriki
Nachricht 6 von 16
1.277 Aufrufe
Nachricht 6 von 16
1.277 Aufrufe
To be honest I have no idea what are storage drivers I am stuck on linux manjaro cuz while installing windows 11 it completely deleted system32 so I had to use my usb I had Linux Manjaro on and now I wanna use tiny11 but I need storage drivers that I have no idea where to find and can't put on usb because BALENA ETCHER combines my partitions into one
BEST REGARDS KIKIRIKI
Kikiriki
Nachricht 7 von 16
1.276 Aufrufe
Nachricht 7 von 16
1.276 Aufrufe
Hi fishtown
I have the Samsung NVME 970 evo SSD and I seen I need kinda a zip file but it gives me an iso and I have no idea what to do
Best regards Kikiriki
Nachricht 8 von 16
1.248 Aufrufe
Nachricht 8 von 16
1.248 Aufrufe
Hello @Kikiriki
Reinstall cleanly:
Why don't you install the original factory installed software Win10 using MediaCreationToo
(all hard drives are recognized?)
and then move on to >> Win11 update >>Tiny11.
The key for Win10 is stored on the computer and the drivers are on the service page.
I don't know Balena etcher and it is a program to create bootable USB drives.
(According to the description, this hides system drives to protect them from being overwritten. Is that why you probably no longer have System32?)
bye Fishtown
Nachricht 9 von 16
1.242 Aufrufe
Nachricht 9 von 16
1.242 Aufrufe
@Fishtown  schrieb:
Hello @Kikiriki
Reinstall cleanly:
(all hard drives are recognized?) and then move on to >> Win11 update >>Tiny11.
@Fishtown
This will not work, because tiny 11 will install it self not as an update, but as a clear installation, and thus has to delete all original Windows content. Otherwise it can not function.
And how comes you advised to contact the seller of memory?  Memory is not storage.
Cheers, daddle
Nachricht 10 von 16
1.236 Aufrufe
Nachricht 10 von 16
1.236 Aufrufe
@daddle
1.Tiny11 requires win11 to build on it but it doesn't work with win10.
2. @Kikiriki asked about memory drivers for his Samsung PCIe. Whereupon I wrote that he should contact the manufacturer to get the drivers from there.
(manufacturer is not the same as seller).
bye Fishtown
15 ANTWORTEN 15
