Need storage drivers for Erazer gaming notebook x7857
15 ANTWOORDEN 15
Kikiriki
Bericht 1 van 16
1.738 Weergaven
Bericht 1 van 16
1.738 Weergaven
Hello i have the erazer x7857 and i need the storage drivers so i can install tiny11 because while installing windows 11 my whole system32 deleted itself and im on manjaro linux right now and it sucks. So i wanna install tiny11 on my laptop but i need storage drivers can someone please find them for me
1 GEACCEPTEERDE OPLOSSING
Geaccepteerd Solutions
Kikiriki
Bericht 14 van 16
1.233 Weergaven
Bericht 14 van 16
1.233 Weergaven
I dont need storage drivers anymore cause i downloaded win11 on a usb i bought new (old one broke) and now im using windows 11
15 ANTWOORDEN 15
Bericht 2 van 16
1.129 Weergaven
Bericht 2 van 16
1.129 Weergaven
hi @Kikiriki and welcome
You can find the existing drivers by entering x7857 on the Medion service page. It is more precise if you enter the MSN number there.
https://www.medion.com/gb/service/product-detail/30025546
bye Fishtown
Kikiriki
Bericht 3 van 16
1.108 Weergaven
Bericht 3 van 16
1.108 Weergaven
Hi Fishtown
These are regular drivers and i need storage drivers i dont need drivers for intel and Nvidia
Bericht 4 van 16
1.098 Weergaven
Bericht 4 van 16
1.098 Weergaven
Hi @Kikiriki
Then you should go to the manufacturer's website where the memory comes from (which you haven't mentioned by name yet).
bye Fishtown
Bericht 5 van 16
1.048 Weergaven
Bericht 5 van 16
1.048 Weergaven
@Kikiriki
Why is talked about storage drivers for memory? Tiny 11 is a reduced Windows 11 version for installation, only 3.7 GB against 6,5 GB install medium volume of normal Windows. With a lot of garbage left out, (That is what they say)
@Kikiriki schrieb:
Hello i have the erazer x7857 and i need the storage drivers so i can install tiny11 because while installing windows 11 my whole system32 deleted itself and im on manjaro linux right now and it sucks. So i wanna install tiny11 on my laptop but i need storage drivers can someone please find them for me.
@Kikiriki
Please  tell me what is the difference between storage drivers an the Intel drivers? Which report talks about "storage drivers"?
I only can image Intels RST drivers are meant. And what about the chipset drivers? Which you have to install firrst. Therefor you do need the original ones first.
Also there could be a  a general incompatibility between your device and tiny 11. Read at XDA devlopers.com
--> https://www.xda-developers.com/tiny11-hands-on/
cheers, daddle
Kikiriki
Bericht 6 van 16
1.040 Weergaven
Bericht 6 van 16
1.040 Weergaven
To be honest I have no idea what are storage drivers I am stuck on linux manjaro cuz while installing windows 11 it completely deleted system32 so I had to use my usb I had Linux Manjaro on and now I wanna use tiny11 but I need storage drivers that I have no idea where to find and can't put on usb because BALENA ETCHER combines my partitions into one
BEST REGARDS KIKIRIKI
Kikiriki
Bericht 7 van 16
1.039 Weergaven
Bericht 7 van 16
1.039 Weergaven
Hi fishtown
I have the Samsung NVME 970 evo SSD and I seen I need kinda a zip file but it gives me an iso and I have no idea what to do
Best regards Kikiriki
Bericht 8 van 16
1.011 Weergaven
Bericht 8 van 16
1.011 Weergaven
Hello @Kikiriki
Reinstall cleanly:
Why don't you install the original factory installed software Win10 using MediaCreationToo
(all hard drives are recognized?)
and then move on to >> Win11 update >>Tiny11.
The key for Win10 is stored on the computer and the drivers are on the service page.
I don't know Balena etcher and it is a program to create bootable USB drives.
(According to the description, this hides system drives to protect them from being overwritten. Is that why you probably no longer have System32?)
bye Fishtown
Bericht 9 van 16
1.005 Weergaven
Bericht 9 van 16
1.005 Weergaven
@Fishtown  schrieb:
Hello @Kikiriki
Reinstall cleanly:
(all hard drives are recognized?) and then move on to >> Win11 update >>Tiny11.
@Fishtown
This will not work, because tiny 11 will install it self not as an update, but as a clear installation, and thus has to delete all original Windows content. Otherwise it can not function.
And how comes you advised to contact the seller of memory?  Memory is not storage.
Cheers, daddle
Bericht 10 van 16
999 Weergaven
Bericht 10 van 16
999 Weergaven
@daddle
1.Tiny11 requires win11 to build on it but it doesn't work with win10.
2. @Kikiriki asked about memory drivers for his Samsung PCIe. Whereupon I wrote that he should contact the manufacturer to get the drivers from there.
(manufacturer is not the same as seller).
bye Fishtown
15 ANTWOORDEN 15
